Re: API Incompatibility still exist | Update of master done [message #1800478 is a reply to message #1800297] |
Sat, 29 December 2018 09:58 |
Ferdinand Trommsdorff Messages: 3 Registered: December 2018 |
Junior Member |
I have updated my local master branch, HEAD is pointing to this commit:
Author: Christoph Weitkamp <github@christophweitkamp.de>
Date: Thu Dec 27 21:16:49 2018 +0100
Actually, within the IDE, the workspace still is set to an older, not working commit. I have tried to update the workspace, marking all files with Ctrl+A and then do a refresh action. But if I try to find out the current git revision, e. g. for a component, then it points to a commit with the following date:
GitHub <noreply@github.com> on 2018-12-23 21:37:27
I have checked the preferences of the workspace within the IDE, but I wasn't lucky until now.
Edit [2018-12-29 11:06]:
I am looking in the "package explorer"-> choose one package -> "properties" -> "git" -> then following the link of "HEAD", which opens the commit information. Here I can see, that all packages are not updated. If I am working outside the IDE on the shell, the updated branch is visible for me.
Edit [2018-12-29 11:15]:
Build from IDE fails with same error as before.
Edit [2018-12-29 11:58]:
Build from command line "mvn clean install" is also not working. Hmm...
[Updated on: Sat, 29 December 2018 11:00] Report message to a moderator
FUDForum. Page generated in 0.03830 seconds
