[EMF Forms] New custom controls [message #1799590] |
Mon, 10 December 2018 17:07 |
sri pamarti Messages: 19 Registered: August 2015 |
Junior Member |
I'm trying to create a new custom control for child objects. I could only find two examples PGroupRenderer and Custom Emailfield renderer.
Which baseclass should I extend if I want to render my own control?
I've used the following in the view model definition for "Custom Control"
Domain Model Reference -> Linked Domain model EFeature for the children
Bundle Name -> bundle name where the RendererService resides
Class Name -> FQN Renderer service class
I tried to emulate the PGroupControl. However I'm getting the following exception
I'm using the latest version 1.18 with eclipse Photon
Custom Control class
public class RolePermissionsControl extends ContainerSWTRenderer<VControl> {
// private ReportService reportService;
@Inject
public RolePermissionsControl(VControl vElement, ViewModelContext viewContext, ReportService reportService,
EMFFormsRendererFactory factory, EMFFormsDatabinding emfFormsDatabinding) {
super(vElement, viewContext, reportService, factory, emfFormsDatabinding);
private SWTGridDescription rendererGridDescription;
private CheckboxTreeViewer treeViewer = null;
public SWTGridDescription getGridDescription(SWTGridDescription gridDescription) {
if (rendererGridDescription == null) {
rendererGridDescription = GridDescriptionFactory.INSTANCE.createSimpleGrid(1, 1, this);
final SWTGridCell swtGridCell = rendererGridDescription.getGrid().get(0);
swtGridCell.setVerticalFill(false);
swtGridCell.setVerticalGrab(false);
return rendererGridDescription;
public Control renderControl(SWTGridCell cell, Composite composite)
throws NoRendererFoundException, NoPropertyDescriptorFoundExeption {
Composite parent = new Composite(composite, SWT.NONE);
parent.setLayout(new FillLayout(SWT.VERTICAL));[/size]
Renderer Service
public class RolePermissionsRendererService implements EMFFormsDIRendererService<VControl> {
private EMFFormsDatabinding databindingService;
* Called by the initializer to set the EMFFormsDatabinding.
* @param databindingService The EMFFormsDatabinding
protected void setEMFFormsDatabinding(EMFFormsDatabinding databindingService) {
this.databindingService = databindingService;
* Called by the initializer to set the ReportService.
* @param reportService The ReportService
protected void setReportService(ReportService reportService) {
this.reportService = reportService;
public double isApplicable(VElement vElement, ViewModelContext viewModelContext) {
if (!VCustomControl.class.isInstance(vElement)) {
return NOT_APPLICABLE;
return 10;
public Class<? extends AbstractSWTRenderer<VControl>> getRendererClass() {
// TODO Auto-generated method stub
return RolePermissionsControl.class;
org.eclipse.e4.core.di.InjectionException: Could not find satisfiable constructor in mypackage.ui.controls.rolepermissions.RolePermissionsControl
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:421)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:331)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:190)
at org.eclipse.emfforms.spi.swt.core.di.EMFFormsDIRendererFactory.getRendererInstance(EMFFormsDIRendererFactory.java:162)
at org.eclipse.emfforms.internal.swt.core.EMFFormsRendererFactoryImpl.getRendererInstance(EMFFormsRendererFactoryImpl.java:102)
at org.eclipse.emf.ecp.view.spi.core.swt.ContainerSWTRenderer.renderControl(ContainerSWTRenderer.java:133)
at org.eclipse.emf.ecp.view.internal.core.swt.renderer.ViewSWTRenderer.renderControl(ViewSWTRenderer.java:100)
at org.eclipse.emfforms.spi.swt.core.AbstractSWTRenderer.render(AbstractSWTRenderer.java:205)
at org.eclipse.emf.ecp.view.internal.swt.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:120)
at org.eclipse.emf.ecp.ui.e4.editor.ECPE4Editor.setInput(ECPE4Editor.java:110)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
[Updated on: Tue, 11 December 2018 04:34] Report message to a moderator
FUDForum. Page generated in 0.02785 seconds
