Drag and drop giving error [message #1798832] |
Mon, 26 November 2018 13:17 |
Gizem Erguder Messages: 2 Registered: November 2018 |
Junior Member |
I'm using RCPTT 2.3.0.
I can record a drag&drop action but whenever i replay it, it gives the following error with script showing success, not fail and drag&drop does not work:
!ENTRY org.eclipse.rcptt.tesla.core 4 0 2018-11-26 15:58:44.473
!MESSAGE org.eclipse.rcptt.tesla.internal.ui.processors.DragSupport.handleDrag:291
!STACK 0
org.eclipse.rcptt.tesla.internal.core.TeslaExecutionFailedException: org.eclipse.rcptt.tesla.internal.ui.processors.DragSupport.handleDrag:291
at org.eclipse.rcptt.tesla.internal.ui.player.SWTUIPlayer$ExecRunnable.run(SWTUIPlayer.java:2700)
at org.eclipse.swt.widgets.RunnableLock.run_aroundBody0(RunnableLock.java:35)
at org.eclipse.swt.widgets.RunnableLock$AjcClosure1.run(RunnableLock.java:1)
at org.eclipse.rcptt.tesla.swt.aspects.DisplayAspect.ajc$around$org_eclipse_rcptt_tesla_swt_aspects_DisplayAspect$10$90b1ba39proceed(DisplayAspect.aj:345)
at org.eclipse.rcptt.tesla.swt.aspects.DisplayAspect.ajc$around$org_eclipse_rcptt_tesla_swt_aspects_DisplayAspect$10$90b1ba39(DisplayAspect.aj:367)
at org.eclipse.swt.widgets.RunnableLock.run_aroundBody2(RunnableLock.java:35)
at org.eclipse.swt.widgets.RunnableLock$AjcClosure3.run(RunnableLock.java:1)
at org.eclipse.rcptt.sherlock.aspects.swt.DisplayAspect.ajc$around$org_eclipse_rcptt_sherlock_aspects_swt_DisplayAspect$2$90b1ba39proceed(DisplayAspect.aj:41)
at org.eclipse.rcptt.sherlock.aspects.swt.DisplayAspect.ajc$around$org_eclipse_rcptt_sherlock_aspects_swt_DisplayAspect$2$90b1ba39(DisplayAspect.aj:63)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4024)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Caused by: java.lang.NullPointerException
at org.eclipse.swt.graphics.Image.destroy(Image.java:751)
at org.eclipse.swt.graphics.Resource.dispose(Resource.java:66)
at org.eclipse.swt.dnd.TreeDragSourceEffect.dragFinished(TreeDragSourceEffect.java:58)
at org.eclipse.swt.dnd.DNDListener.handleEvent(DNDListener.java:43)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4230)
at org.eclipse.swt.widgets.Widget.sendEvent_aroundBody2(Widget.java:1491)
at org.eclipse.swt.widgets.Widget$AjcClosure3.run(Widget.java:1)
at org.eclipse.rcptt.tesla.recording.aspects.RecordingAspect.ajc$around$org_eclipse_rcptt_tesla_recording_aspects_RecordingAspect$2$2f127892proceed(RecordingAspect.aj:96)
at org.eclipse.rcptt.tesla.recording.aspects.RecordingAspect.ajc$around$org_eclipse_rcptt_tesla_recording_aspects_RecordingAspect$2$2f127892(RecordingAspect.aj:120)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1491)
at org.eclipse.swt.widgets.Widget.sendEvent_aroundBody4(Widget.java:1514)
at org.eclipse.swt.widgets.Widget$AjcClosure5.run(Widget.java:1)
at org.eclipse.rcptt.tesla.recording.aspects.RecordingAspect.ajc$around$org_eclipse_rcptt_tesla_recording_aspects_RecordingAspect$1$bd9fb3e7proceed(RecordingAspect.aj:41)
at org.eclipse.rcptt.tesla.recording.aspects.RecordingAspect.ajc$around$org_eclipse_rcptt_tesla_recording_aspects_RecordingAspect$1$bd9fb3e7(RecordingAspect.aj:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1503)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1499)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1299)
at org.eclipse.rcptt.tesla.internal.ui.player.SWTEvents.sendEventRaw(SWTEvents.java:87)
at org.eclipse.rcptt.tesla.internal.ui.player.SWTEvents.sendEvent(SWTEvents.java:200)
at org.eclipse.rcptt.tesla.internal.ui.processors.DragSupport.doDragEnd(DragSupport.java:467)
at org.eclipse.rcptt.tesla.internal.ui.processors.DragSupport.access$22(DragSupport.java:461)
at org.eclipse.rcptt.tesla.internal.ui.processors.DragSupport$2.run(DragSupport.java:331)
at org.eclipse.rcptt.tesla.internal.ui.player.SWTUIPlayer$ExecRunnable.run(SWTUIPlayer.java:2694)
... 35 more
Any ideas how to drag & drop?
[Updated on: Mon, 26 November 2018 14:09] Report message to a moderator
FUDForum. Page generated in 0.03152 seconds
