Eclipse (SimRel 2018‑09) formatter (configuration) on save broken? [message #1797381] |
Tue, 30 October 2018 13:10 |
Hilbrand Bouwkamp Messages: 5 Registered: October 2017 |
Junior Member |
I've installed the latest version of Eclipse (Photon) Smart Home and it formats the JavaDoc wrong on save. For example it changes:
* @param channelUID the {@link ChannelUID} of the channel to which the command was sent
* @param command the {@link Command}
into:
When I try to open the Java -> Code Style -> Formatter and want to edit a template Eclipse hangs temporary and in the log file the following exception is thrown:
!ENTRY org.eclipse.ui 4 0 2018-10-30 10:14:33.533
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.IllegalArgumentException: Alignment value is not an integer: null
at org.eclipse.jdt.core.formatter.DefaultCodeFormatterConstants.getWrappingStyle(DefaultCodeFormatterConstants.java:4554)
at org.eclipse.jdt.internal.ui.preferences.formatter.FormatterModifyDialog$LineWrapPreference.updateWidget(FormatterModifyDialog.java:211)
at org.eclipse.jdt.internal.ui.preferences.formatter.ModifyDialog$Preference.init(ModifyDialog.java:280)
at org.eclipse.jdt.internal.ui.preferences.formatter.FormatterModifyDialog$LineWrapPreference.init(FormatterModifyDialog.java:205)
at org.eclipse.jdt.internal.ui.preferences.formatter.ModifyDialog$ProfilePreferenceTree.addChild(ModifyDialog.java:907)
at org.eclipse.jdt.internal.ui.preferences.formatter.FormatterModifyDialog.lambda$20(FormatterModifyDialog.java:1225)
at org.eclipse.jdt.internal.ui.preferences.formatter.ModifyDialog$ProfilePreferenceTree$PrefBuilder.build(ModifyDialog.java:839)
at org.eclipse.jdt.internal.ui.preferences.formatter.ModifyDialog$ProfilePreferenceTree$PrefBuilder.build(ModifyDialog.java:1)
at org.eclipse.jdt.internal.ui.preferences.formatter.ModifyDialog$ProfilePreferenceTree$SectionBuilder.build(ModifyDialog.java:822)
at org.eclipse.jdt.internal.ui.preferences.formatter.ModifyDialog$ProfilePreferenceTree$SectionBuilder.build(ModifyDialog.java:1)
at org.eclipse.jdt.internal.ui.preferences.formatter.FormatterModifyDialog.createLineWrapTree(FormatterModifyDialog.java:1207)
at org.eclipse.jdt.internal.ui.preferences.formatter.FormatterModifyDialog.createPreferenceTree(FormatterModifyDialog.java:575)
at org.eclipse.jdt.internal.ui.preferences.formatter.ModifyDialog.createMainArea(ModifyDialog.java:1262)
at org.eclipse.jdt.internal.ui.preferences.formatter.ModifyDialog.createDialogArea(ModifyDialog.java:1246)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:771)
at org.eclipse.jface.window.Window.create(Window.java:429)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1099)
at org.eclipse.jface.dialogs.StatusDialog.create(StatusDialog.java:203)
at org.eclipse.jface.window.Window.open(Window.java:786)
at org.eclipse.jdt.internal.ui.preferences.formatter.ProfileConfigurationBlock$ButtonController.modifyButtonPressed(ProfileConfigurationBlock.java:231)
at org.eclipse.jdt.internal.ui.preferences.formatter.ProfileConfigurationBlock$ButtonController.widgetSelected(ProfileConfigurationBlock.java:175)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:252)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5797)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1374)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:5051)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4583)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:821)
at org.eclipse.jface.window.Window.open(Window.java:797)
at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.open(WorkbenchPreferenceDialog.java:214)
at org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPreferencesAction.java:66)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:476)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:568)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:400)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:628)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:563)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:155)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:199)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:391)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:246)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595)
at org.eclipse.equinox.launcher.Main.run(Main.java:1501)
at org.eclipse.equinox.launcher.Main.main(Main.java:1474)
Caused by: java.lang.NumberFormatException: null
at java.lang.Integer.parseInt(Integer.java:542)
at java.lang.Integer.parseInt(Integer.java:615)
at org.eclipse.jdt.core.formatter.DefaultCodeFormatterConstants.getWrappingStyle(DefaultCodeFormatterConstants.java:4538)
... 61 more
Eclipse IDE for Java Developers
Version: 2018-09 (4.9.0)
Build id: 20180917-1800
Edit
Changed title to correct Eclipse edition this problem was found in: SimRel 2018‑09
[Updated on: Thu, 01 November 2018 07:20] Report message to a moderator
FUDForum. Page generated in 0.02923 seconds
