Deployment package plugins already installed [message #1796807] |
Fri, 19 October 2018 07:23 |
Valentas Malakauskas Messages: 4 Registered: March 2018 |
Junior Member |
We created deployment package resolver which generates feature.xml with all required plugins inside, which makes stand alone deployment packages.
But we came to a problem where if we have 2 DP's that have same plugin defined, the second DP installation fails with error that such bundle is already installed.
There is a few approaches that we could take, either create a runtime resolver which creates features with plugins inside that are required by a bundle but not already installed. Or strictly define core DP and then create feature DP's that only come with there own bundles which would probably still lead to duplicates.
Is there any other approaches we could take or maybe we could do something with kura deployment where when DP is installed we could check if bundle already installed and just ignore it?
FUDForum. Page generated in 0.03208 seconds
