| Adding to "Debug As..." sub menu? [message #334718] |
Wed, 25 February 2009 09:06  |
Is there any way I can add additional "shortcuts" to the "Debug As..."
submenu (under "Run" and the right-click menu for a binary file)?
Specifically, for a C++ application I get one entry by default - "Local
C/C++ application". I'd really like to have "C/C++ Postmortem debugger"
and "C/C++ Attach to Local Application" as well - so that I won't have to
add special debug configurations for each and every program to get access
to these (very useful) debug options.
I can't seem to find anything about this, or the "Debug as" menu in
general in the debug documentation, but perhaps I'm looking at the wrong
place...
| Re: Adding to "Debug As..." sub menu? [message #334762 is a reply to message #334761] |
Thu, 26 February 2009 08:40  |
Hitesh wrote:
> Toralf Lund wrote:
>> No...
>> I'm not sure I follow you. Are you saying that I have to add or modify a
>> plugin to do this kind of thing? I was rather hoping I could configure a
> If you wanted a Launch-shortcut to appear in the run and/or debug sub
> menus, you would have to declare an extension to this point. This is a
> task for a plug-in developer.
OK. Fair enough.
>> "link" between the menu and other GUI items, like "Debug configurations",
>> from within the GUI itself...
> If the plug-in developer had provided such a shortcut, it would have been
> available in the run/debug sub menu.
What I was trying to say, is that it seems to me it should be possible to
have a menu like "Debug as" automatically pick up the configuration types
available from "Debug Configuration" (and similarly for "Run as"/"Run
configuration"), without the need for a "shortcut" definition as such. But
maybe that's yet another feature request...
> Since you are looking for C/C++
> launch shortcuts, this sounds like a feature request for CDT. You may
> discuss this on the CDT newsgroup :
> http://www.eclipse.org/newsportal/thread.php?group=eclipse.t ools.cdt
Yeah, maybe I'll ask there, and/or check the appropriate component in
Bugzilla...
- Toralf
FUDForum. Page generated in 0.03769 seconds
