Difference between BIRT Designer & Runtime using Excel emitter [message #1794000] |
Wed, 22 August 2018 07:41 |
Eti Ga Messages: 8 Registered: June 2018 |
Junior Member |
BIRT version : 4.4.2 but I can't make it work with 4.8 neither.
I'm facing a "weird" issue where the rendering I have when creating a simple report in BIRT designer is different from the result when I generate the same report using the BIRT Runtime.
The report :
* A grid with 3 lines
* Each line has a "page break always"
> When I generate it to XLSX in the BIRT Designer, I have one tab per page break ( Preview -> XLSX) --> That's the result I want
> When I generate it to XLSX using the BIRT Runtime (same version) all the lines are on the same tab ... (options.setOutputFormat("xlsx"); )
Does someone have any idea or a different behavior ?
Thanks in advance
[Updated on: Wed, 22 August 2018 10:54] Report message to a moderator
FUDForum. Page generated in 0.03114 seconds
