How to connect Kura gateway to Hono [message #1793587] |
Fri, 10 August 2018 15:36 |
Mohab Aly Messages: 5 Registered: July 2018 |
Junior Member |
I am trying to connect my Kura gateway (on Raspberry Pi) to Hono (deployed on my local machine). However, I could not do that.
As far as I see in Hono documentation, it is possible to connect any gateway via protocol adapters which are linked to QPID dispatch router and Kura can communicate with MQTT broker directly at the cloud side.
Additional information: I tried the port-forwarding option on Hono based on the recommendations at [1] (i.e., the ticket I opened on Github), but unfortunately, it is not working; there is a bug related to that [2].
If there is any alternative or workaround, I'd be delighted to hear about it.
Appreciate if anybody could help me. Thank you in advance.
Mohab
[1] https://github.com/eclipse/hono/issues/763
[2] https://github.com/kubernetes/kubernetes/pull/46517
[Updated on: Fri, 10 August 2018 16:28] Report message to a moderator
FUDForum. Page generated in 0.03217 seconds
