Home » Eclipse Projects » WindowBuilder » WindowBuilder Update Fail
WindowBuilder Update Fail [message #1793303] |
Fri, 03 August 2018 13:43 |
Avi Abrami Messages: 31 Registered: December 2017 |
Member |
Eclipse IDE for Java Developers
Version: Photon Release (4.8.0)
Build id: 20180619-1200
Displayed WindowBuilder version: 1.10.0.201807310629
A few days ago, Photon informed me of available updates for WindowBuilder and successfully installed them.
My installation site is:
http://download.eclipse.org/windowbuilder/WB/integration/4.8/
Today Photon again informed me that there were available updates but failed to install them. The error details were as follows:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.java, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.wb.core,1.10.0.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.core.databinding,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.core.databinding.xml,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.core.java,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.core.lib,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.core.ui,1.10.0.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.core.xml,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.doc.user,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.layout.group,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.os,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.os.win32,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.rcp,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.rcp.SWT_AWT,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.rcp.databinding,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.rcp.databinding.emf,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.rcp.databinding.xwt,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.rcp.doc.user,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.rcp.nebula,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.rcp.swing2swt,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.runtime,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.runtime.lib,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.swing,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.swing.FormLayout,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.swing.FormLayout.lib,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.swing.MigLayout,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.swing.MigLayout.lib,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.swing.databinding,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.swing.doc.user,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.swing.java6,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.swing.jsr296,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.swt,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.swt.widgets.baseline,1.9.1.201808020629
No repository found containing: osgi.bundle,org.eclipse.wb.xwt,1.9.1.201808020629
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.core.feature,1.9.1.201808020629
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.core.java.feature,1.9.1.201808020629
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.core.ui.feature,1.9.1.201808020629
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.core.xml.feature,1.9.1.201808020629
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.doc.user.feature,1.9.1.201808020629
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.layout.group.feature,1.9.1.201808020629
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.rcp.SWT_AWT_support,1.9.1.201808020629
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.rcp.doc.user.feature,1.9.1.201808020629
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.rcp.feature,1.9.1.201808020629
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.swing.doc.user.feature,1.9.1.201808020629
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.swing.feature,1.9.1.201808020629
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.swt.feature,1.9.1.201808020629
No repository found containing: org.eclipse.update.feature,org.eclipse.wb.xwt.feature,1.9.1.201808020629
Current Time: Sun May 05 11:20:34 GMT 2024
Powered by FUDForum. Page generated in 0.02665 seconds
