RCPTT working with Eclipse Photon? [message #1792271] |
Fri, 13 July 2018 18:08 |
Tim Kosacek Messages: 3 Registered: June 2016 |
Junior Member |
Does RCPTT 2.3.0 work with Eclipse Photon? When I try to create an Eclipse application under test and launch it I get the following stacktrace:
java.lang.NoSuchMethodError: org.eclipse.pde.internal.core.PDECore.acquireService(Ljava/lang/String;)Ljava/lang/Object;
at org.eclipse.rcptt.launching.p2utils.P2Utils.getTargetService(P2Utils.java:72)
at org.eclipse.rcptt.launching.internal.target.PDEHelper.getTargetService(PDEHelper.java:32)
at org.eclipse.rcptt.launching.target.TargetPlatformManager.findTarget(TargetPlatformManager.java:111)
at org.eclipse.rcptt.launching.configuration.Q7LaunchConfigurationDelegate.preLaunchCheck(Q7LaunchConfigurationDelegate.java:133)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:814)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:717)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1256)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:60)
The same launch file will work fine with previous Eclipse versions (RCPTT 2.2.0).
[Updated on: Fri, 13 July 2018 18:09] Report message to a moderator
FUDForum. Page generated in 0.03334 seconds
