Build is taking very long time and failing [message #1792117] |
Wed, 11 July 2018 20:54 |
Nagarjuna Reddy Kurmayyagari Messages: 1 Registered: July 2018 |
Junior Member |
I am trying build my project using Hudson and it is taking very long time and when i try to kill the job, it is not letting me and i have to stop and start the server to stop the job and build shows failure with below log. Kindly help me on this.
started
FATAL: name
java.lang.NullPointerException: name
at java.util.zip.ZipFile.getEntry(Unknown Source)
at java.util.jar.JarFile.getEntry(Unknown Source)
at java.util.jar.JarFile.getJarEntry(Unknown Source)
at sun.misc.URLClassPath$JarLoader.getResource(Unknown Source)
at sun.misc.URLClassPath.getResource(Unknown Source)
at java.lang.ClassLoader.getBootstrapResource(Unknown Source)
at java.lang.ClassLoader.getResource(Unknown Source)
at java.lang.ClassLoader.getResourceAsStream(Unknown Source)
at org.apache.catalina.loader.WebappClassLoader.getResourceAsStream(WebappClassLoader.java:1181)
at java.lang.Class.getResourceAsStream(Unknown Source)
at org.tmatesoft.svn.util.Version.loadProperties(Version.java:116)
at org.tmatesoft.svn.util.Version.getVersionString(Version.java:48)
at org.tmatesoft.svn.util.Version.getUserAgent(Version.java:60)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPRequest.composeHTTPHeader(HTTPRequest.java:305)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPRequest.dispatch(HTTPRequest.java:157)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:321)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:255)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:243)
at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.exchangeCapabilities(DAVConnection.java:452)
at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.open(DAVConnection.java:95)
at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.openConnection(DAVRepository.java:642)
at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.testConnection(DAVRepository.java:95)
at hudson.scm.SubversionSCM$DescriptorImpl.checkRepositoryPath(SubversionSCM.java:1342)
at hudson.scm.SubversionSCM.repositoryLocationsExist(SubversionSCM.java:1407)
at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:382)
at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:345)
at hudson.model.AbstractProject.checkout(AbstractProject.java:664)
at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:260)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:234)
at hudson.model.Run.run(Run.java:793)
at hudson.model.Build.run(Build.java:88)
at hudson.model.ResourceController.execute(ResourceController.java:70)
at hudson.model.Executor.run(Executor.java:88)
FUDForum. Page generated in 0.03682 seconds
