Problem in loading Virgo bundles for vSphere v6.5 [message #1791297] |
Wed, 27 June 2018 19:24 |
David Oz Messages: 1 Registered: June 2018 |
Junior Member |
We're working on upgrading our Virgo development environment for working with vSphere v6.5 (our current version works with vSphere v5.5, and it works ok)
We have 5 Java Eclipse projects that represent 5 different OSGi bundles (compilation output is 5 jar files).
The providerAdapter bundle is deployed on the Virgo server and relies on the other 4 bundles.
After extracting the vsphere-Webclient-sdk-6.5.0-8307201 zip, and adjusting the Eclipse projects settings accordingly, we place the 4 jar files under
vsphere-Webclient-sdk-6.5.0-8307201\flex-client-sdk\vsphere-client\server\repository\usr as instructed.
However, it seems that these jars are not loaded as part of the Virgo server startup, and we end up with an error message:
An Import-Package could not be resolved. Resolver error data <Import-Package: com.e.e.v.common.models.deploy; version="1.0.0">. Caused by missing constraint in bundle <com.e.s.s.v.providerAdapters_1.0.0.SNAPSHOT>
constraint: <Import-Package: com.e.e.v.common.models.deploy; version="1.0.0">
I should note the com.e.e.v.common is one of the 4 bundles which providerAdapters relies on.
We've also tried placing the jars under vsphere-Webclient-sdk-6.5.0-8307201\flex-client-sdk\vsphere-client\server\repository\ext folder, but get the same result.
Dave O
FUDForum. Page generated in 0.03405 seconds
