[EMF Forms] Non-ASCII viewmodel generation [message #1787606] |
Tue, 29 May 2018 22:45 |
Akira Tanaka Messages: 98 Registered: March 2010 |
Member |
Hello EMF Forms experts,
Is there any way to apply EMF Forms to non-ASCII encoded ecore models? In my case, I was able to create non-ASCII (Japanese with UTF-8 setting) ecore model, which contains non-ASCII EClass name as well as non-ASCII attribute names. I was then able to generate model code and edit project (EMF works!). However, when i tried to generate EMF Form's viewmodel project, I got an error in viewmodel. The viewmodel in textual form is an XML file with ASCII as default coding. Although just changing "ASCII" to "UTF-8" did not work, I exported the viewmodel file, did edit with external editor and saved it as UTF-8 encoded file, imported it back to viewmodel project, it worked (EClass name was successfully shown but no control for attributes were generated).
My question is "is there any way to specify/generate UTF-8 encoded viewmodel?" How can I achieve this?
Thank you for your help in advance.
Akira
FUDForum. Page generated in 0.03820 seconds
