WB not working in Linux and Windows 7 + Photon 4.8.0RC1 [message #1787586] |
Tue, 29 May 2018 16:23 |
maybe the problem is only due to the undergoing work on the Photon Eclipse Train, but just in case I would like to make it known.
I am testing WB (1.9.0, from IDE Marketplace) on latest Photon build
Quote:Eclipse IDE for RCP and RAP Developers
Version: Photon Release Candidate 1 (4.8.0RC1)
Build id: 20180524-1423
OS: Linux, v.4.15.0-22-generic, x86_64 / gtk 3.22.30, WebKit 2.20.2
Java version: 1.8.0_171
Linux=Ubuntu LTS 18.04 / GNOME
Windows=Windows 7
but when I try to open a view I see an empty area while the Error Log shows:
Unhandled event loop exception
at org.eclipse.wb.internal.core.editor.UndoManager.addSelectionListener(UndoManager.java:187)
at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:382)
at org.eclipse.wb.internal.core.editor.UndoManager.activate(UndoManager.java:90)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState_True(DesignPage.java:263)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState(DesignPage.java:241)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.showPage(DefaultMultiMode.java:125)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode$1.widgetSelected(DefaultMultiMode.java:63)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5686)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1370)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1396)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1379)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1164)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3195)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1878)
at org.eclipse.swt.custom.CTabFolder.lambda$0(CTabFolder.java:328)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4940)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4518)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1170)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1059)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:683)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:597)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
at org.eclipse.equinox.launcher.Main.main(Main.java:1471)
Is there some others having the same issue?
Thank you very much
Vincenzo
[Updated on: Wed, 30 May 2018 10:43] Report message to a moderator
FUDForum. Page generated in 0.04245 seconds
