Can not connect Krua device to kapua server exception Not authorized to connect (5) [message #1787356] |
Thu, 24 May 2018 04:15 |
Hemant Sangle Messages: 3 Registered: January 2018 |
Junior Member |
I haven't changed the setting of CloudServiceSetting in kura not even the client-id but still I get this error below is log of kura device
2018-05-23 14:27:17,894 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - Creating a new client instance
2018-05-23 14:27:17,895 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - Using memory persistence for in-flight messages
2018-05-23 14:27:17,897 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - # ------------------------------------------------------------
2018-05-23 14:27:17,898 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - # Connection Properties
2018-05-23 14:27:17,898 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - # broker = tcp://35.173.87.174:1883
2018-05-23 14:27:17,899 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - # clientId = 51284
2018-05-23 14:27:17,899 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - # username = kapua-broker
2018-05-23 14:27:17,900 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - # password = XXXXXXXXXXXXXX
2018-05-23 14:27:17,900 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - # keepAlive = 30
2018-05-23 14:27:17,900 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - # timeout = 20
2018-05-23 14:27:17,901 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - # cleanSession = true
2018-05-23 14:27:17,901 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - # MQTT version = 3.1.1
2018-05-23 14:27:17,901 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - # willDestination = $EDC/kapua-sys/51284/MQTT/LWT
2018-05-23 14:27:17,902 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - # willMessage =
2018-05-23 14:27:17,903 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - # Connecting...
2018-05-23 14:27:17,903 [pool-9-thread-1] INFO o.e.k.c.s.r.LogStatusRunnable - Notification LED fast blinking
2018-05-23 14:27:18,572 [qtp4810959-46] WARN o.e.k.c.d.t.m.MqttDataTransport - xxxxx Connect failed. Forcing disconnect. xxxxx {}
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:28)
at org.eclipse.paho.client.mqttv3.internal.ClientState.notifyReceivedAck(ClientState.java:990)
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:118)
at java.lang.Thread.run(Thread.java:745)
2018-05-23 14:27:18,574 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - Closing client...
2018-05-23 14:27:18,578 [qtp4810959-46] INFO o.e.k.c.d.t.m.MqttDataTransport - Closed
2018-05-23 14:27:18,579 [pool-9-thread-1] INFO o.e.k.c.s.r.LogStatusRunnable - Notification LED off
2018-05-23 14:27:18,579 [qtp4810959-46] WARN o.e.k.w.s.GwtNetworkServiceImpl - Error connecting
org.eclipse.kura.KuraConnectException: "Connection failed. Cannot connect"
at org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport.connect(MqttDataTransport.java:333)
at org.eclipse.kura.core.data.DataServiceImpl.connect(DataServiceImpl.java:493)
at org.eclipse.kura.web.server.GwtStatusServiceImpl.connectDataService(GwtStatusServiceImpl.java:93)
at java.lang.reflect.Method.invoke(Method.java:497)
at com.google.gwt.user.server.rpc.RPC.invokeAndEncodeResponse(RPC.java:587)
at com.google.gwt.user.server.rpc.RemoteServiceServlet.processCall(RemoteServiceServlet.java:333)
at com.google.gwt.user.server.rpc.RemoteServiceServlet.processCall(RemoteServiceServlet.java:303)
at com.google.gwt.user.server.rpc.RemoteServiceServlet.processPost(RemoteServiceServlet.java:373)
at com.google.gwt.user.server.rpc.AbstractRemoteServiceServlet.doPost(AbstractRemoteServiceServlet.java:62)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.eclipse.kura.web.server.OsgiRemoteServiceServlet.service(OsgiRemoteServiceServlet.java:41)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl$LegacyServlet.service(HttpServiceRuntimeImpl.java:1221)
at org.eclipse.equinox.http.servlet.internal.registration.EndpointRegistration.service(EndpointRegistration.java:153)
at org.eclipse.equinox.http.servlet.internal.servlet.ResponseStateHandler.processRequest(ResponseStateHandler.java:62)
at org.eclipse.equinox.http.servlet.internal.context.DispatchTargets.doDispatch(DispatchTargets.java:132)
at org.eclipse.equinox.http.servlet.internal.servlet.ProxyServlet.service(ProxyServlet.java:100)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:310)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:845)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:224)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1174)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1106)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
at org.eclipse.jetty.server.Server.handle(Server.java:524)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:319)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:253)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589)
Caused by: Not authorized to connect (5)
... 1 more
FUDForum. Page generated in 0.03395 seconds
