Re: How to get advertisement data via new "BluetoothLeAdapter" [message #1818342 is a reply to message #1817766] |
Fri, 13 December 2019 00:03 |
Joachim Kroeger Messages: 4 Registered: November 2019 |
Junior Member |
In the meantime I figured it out, basically.
I followed the osgi example for 'hello world' and startet debugging.
I modified the example code for the TI sensortags, because it is all deprecated with kura 4.1
Because I do not use these TI devices, I built it as clean code for universal GATT protocol devices. Work in progress, but the callback on value changes is not running yet.
My question is now: What is the best, shortest way, to have a robust, reliable compile, deploy, debug cycle using the osgi connection with the debug script, which allows to debug my code? Target is a Raspi 4.
During deploy, I get virtually dozens of popups and lots of error messages, that the deployment runs into error situations. After 2 or more cycles, I can debug fresh modified sources.
But the sequence of steps is confusing me!
Re: How to get advertisement data via new "BluetoothLeAdapter" [message #1819012 is a reply to message #1819009] |
Sat, 04 January 2020 16:30 |
Junior Member |
Hello Matteo,
I get multiple identical error messages (popups), which are unspecific, no explenations, but say: deployment failed. And lots, which state, already installed.
If I understand right, the applications (bundles) can cause these errors themself ?
The popups appear within eclipse.
I do not use maven. So I will search for that plugin.
Nevertheless, I have a very minor understanding of the OSGI framework.
Thanks a lot for your response!
Happy new year,
Greetings,
Joachim
FUDForum. Page generated in 0.03456 seconds
