Kura Emulator - missing native library for RXTX [message #1781541] |
Thu, 08 February 2018 10:31 |
Carel Kruger Messages: 1 Registered: February 2018 |
Junior Member |
HI All,
I am trying to run the serial bundle example in the Kura emulator
I have followed all the instructions, but get the following error if I try to open the serial port :
java.lang.UnsatisfiedLinkError: javax.comm.RXTXCommDriver.nativeGetVersion()Ljava/lang/String; thrown while loading javax.comm.RXTXCommDriver
java.lang.NoClassDefFoundError: Could not initialize class javax.comm.RXTXCommDriver thrown while loading javax.comm.RXTXCommDriver
From the above output I can deduce that the native library is missing for rxtx. I have tried to include the native library using the Bundle-NativeCode directive directly in the bundle without luck. I assume this does not work because the javax.comm is not called in my bundle but via the connection factory somewhere else .
When I look at the eclipse workspace target definition I can see a jar file under the plugin directory named " javax.comm.x86_64_2.2.200.jar" which has the correct librxtxSerial.so file in it for 64bit (I am running eclipse on a 64 bit version of Debian 9).
Is it possible to run serial communications in the Kura emulator and if it is what do I need to do to get the native libraries resolved ?
Thank-you
Carel
FUDForum. Page generated in 0.03502 seconds
