Re: Getting error while doing maven clean install [message #1780635 is a reply to message #1780601] |
Thu, 25 January 2018 06:56 |
Paramesh Surakod Messages: 15 Registered: January 2018 |
Junior Member |
Thank you for the reply sir,
ya i did both options, i deleted manually and also executed command that u have provided above but with both case i am getting the same error
[INFO] --- frontend-maven-plugin:1.0:install-node-and-npm (Install node and npm) @ org.eclipse.smarthome.ui.paper ---
[INFO] Installing node version v8.1.2
[INFO] Copying node binary from C:\Users\Asus_Fueb1\.m2\repository\com\github\eirslett\node\8.1.2\node-8.1.2-windows-x64.exe to C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node\node.exe
[INFO] Installed node locally.
[INFO] Installing npm version 5.0.3
[INFO] Unpacking C:\Users\Asus_Fueb1\.m2\repository\com\github\eirslett\npm\5.0.3\npm-5.0.3.tar.gz into C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node\node_modules
[INFO] Installed npm locally.
[INFO]
[INFO] --- frontend-maven-plugin:1.0:npm (npm install) @ org.eclipse.smarthome.ui.paper ---
[INFO] Running 'npm install' in C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper
[WARNING] npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
[WARNING] npm WARN deprecated gulp-util@2.2.20: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
[WARNING] npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
[WARNING] npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
[WARNING] npm WARN deprecated express@2.5.11: express 2.x series is deprecated
[WARNING] npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
[WARNING] npm WARN deprecated connect@1.9.2: connect 1.x series is deprecated
[WARNING] npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
[WARNING] npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
[WARNING] npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: repeat-string@0.2.2 (node_modules\expand-braces\node_modules\repeat-string):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, utime 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\repeat-string-942d116d\.npmignore'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: expand-range@0.1.1 (node_modules\expand-braces\node_modules\expand-range):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, utime 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\expand-range-ffad84bf\.npmignore'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: braces@0.1.5 (node_modules\expand-braces\node_modules\braces):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, utime 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\braces-315cfdc8\.npmignore'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: is-number@0.1.1 (node_modules\expand-braces\node_modules\is-number):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, utime 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\is-number-c3efc22c\.npmignore'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: eventie@1.0.6 (node_modules\eventie):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, utime 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\eventie-0a3d9066\README.md'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: lodash@4.17.4 (node_modules\lodash):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, open 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\lodash-be2752ff\deburr.js'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: async@2.4.1 (node_modules\async):
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: EEXIST: file already exists, mkdir 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\async-952b1f5b'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File exists: C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\async-952b1f5b
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: event-emitter@0.3.5 (node_modules\event-emitter):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, open 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\event-emitter-21325be0\.npmignore'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: browser-sync-client@2.5.1 (node_modules\browser-sync-client):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, open 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\browser-sync-client-364b1e69\README.md'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: extsprintf@1.3.0 (node_modules\extsprintf):
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: EEXIST: file already exists, mkdir 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\extsprintf-60a71111'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File exists: C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\extsprintf-60a71111
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mime@1.2.4 (node_modules\express\node_modules\mime):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, utime 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\mime-945aa4cd\LICENSE'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: connect@1.9.2 (node_modules\express\node_modules\connect):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, open 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\connect-97b2d9eb\lib\patch.js'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: lodash@3.10.1 (node_modules\opt-merger\node_modules\lodash):
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: EEXIST: file already exists, mkdir 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\lodash-43a36599\object'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File exists: C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\lodash-43a36599\object
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: lodash@1.0.2 (node_modules\glob-watcher\node_modules\lodash):
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: EEXIST: file already exists, mkdir 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\lodash-641bedf0\dist'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File exists: C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\lodash-641bedf0\dist
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: es6-map@0.1.5 (node_modules\es6-map):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, utime 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\es6-map-0c27b93e\README.md'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: flagged-respawn@1.0.0 (node_modules\flagged-respawn):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, utime 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\flagged-respawn-70645176\index.js'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: es6-set@0.1.5 (node_modules\es6-set):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, utime 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\es6-set-36e19c72\README.md'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ajv@4.11.8 (node_modules\ajv):
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: EEXIST: file already exists, mkdir 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\ajv-05ca68ce\lib\compile'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File exists: C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\ajv-05ca68ce\lib\compile
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluebird@3.4.7 (node_modules\jsdoc\node_modules\bluebird):
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: EEXIST: file already exists, mkdir 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\bluebird-dca5c58d\js\release'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File exists: C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\bluebird-dca5c58d\js\release
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: qs@0.4.2 (node_modules\express\node_modules\qs):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, utime 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\qs-9ee7025d\History.md'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: expand-braces@0.1.2 (node_modules\expand-braces):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, utime 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\expand-braces-34cd6e42\readme.md'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: weinre@2.0.0-pre-I0Z7U9OV (node_modules\weinre):
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: EEXIST: file already exists, mkdir 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\weinre-8ce041d4\web\client\Images'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File exists: C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\weinre-8ce041d4\web\client\Images
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: formidable@1.0.17 (node_modules\formidable):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, open 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\formidable-84652e6f\lib\octet_parser.js'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: express@2.5.11 (node_modules\express):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, open 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\express-a18228a6\lib\response.js'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fast-deep-equal@1.0.0 (node_modules\fast-deep-equal):
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: EEXIST: file already exists, mkdir 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\fast-deep-equal-3153dde1\benchmark'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File exists: C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\fast-deep-equal-3153dde1\benchmark
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mout@0.10.0 (node_modules\mout):
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: EEXIST: file already exists, mkdir 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\mout-a9235fbf\array'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File exists: C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\mout-a9235fbf\array
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: iconv-lite@0.4.19 (node_modules\iconv-lite):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, utime 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\iconv-lite-f8d563c4\lib\index.js'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: lodash@3.10.1 (node_modules\karma\node_modules\lodash):
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: EEXIST: file already exists, mkdir 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\lodash-dd1eba5b\collection'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File exists: C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\lodash-dd1eba5b\collection
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.1.3 (node_modules\fsevents):
[WARNING] npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, utime 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\fsevents-39ffd3a4\node_modules\aproba\README.md'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: lodash@3.10.1 (node_modules\http-proxy-middleware\node_modules\lodash):
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: EEXIST: file already exists, mkdir 'C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\lodash-47df3ff5\object'
[WARNING] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File exists: C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node_modules\.staging\lodash-47df3ff5\object
[ERROR]
[ERROR] npm ERR! code EINTEGRITY
[ERROR] npm ERR! sha1-qced3wuE72sv5IoNEVe0JWioH1o= integrity checksum failed when using sha1: wanted sha1-qced3wuE72sv5IoNEVe0JWioH1o= but got sha1-R7ay3ttvDgcr6+IRV/u4Hr4khaY=. (261548 bytes)
[ERROR]
[ERROR] npm ERR! A complete log of this run can be found in:
[ERROR] npm ERR! C:\Users\Asus_Fueb1\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\npm_cache\_logs\2018-01-25T06_43_45_155Z-debug.log
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO]
[INFO] Eclipse SmartHome .................................. SUCCESS [ 5.491 s]
[INFO] Eclipse SmartHome Bundles .......................... SUCCESS [ 1.450 s]
[INFO] Eclipse SmartHome Test Components .................. SUCCESS [ 0.094 s]
[INFO] Eclipse SmartHome Core Components .................. SUCCESS [ 0.090 s]
[INFO] Eclipse SmartHome Core ............................. SUCCESS [01:18 min]
[INFO] Eclipse SmartHome Configurations ................... SUCCESS [ 0.140 s]
[INFO] Eclipse SmartHome Configuration Core ............... SUCCESS [ 18.269 s]
[INFO] Eclipse SmartHome Configuration XML ................ SUCCESS [ 15.276 s]
[INFO] Eclipse SmartHome AutoUpdate Binding ............... SUCCESS [ 10.520 s]
[INFO] Eclipse SmartHome Test ............................. SUCCESS [ 12.832 s]
[INFO] Eclipse SmartHome I/O Components ................... SUCCESS [ 0.109 s]
[INFO] Eclipse SmartHome Console .......................... SUCCESS [ 9.642 s]
[INFO] Eclipse SmartHome Thing ............................ SUCCESS [ 27.856 s]
[INFO] Magic Bundle ....................................... SUCCESS [ 10.139 s]
[INFO] Magic Bundle Tests ................................. SUCCESS [ 8.572 s]
[INFO] Eclipse SmartHome Auth Components .................. SUCCESS [ 0.141 s]
[INFO] Eclipse SmartHome JAAS Authentication .............. SUCCESS [ 9.206 s]
[INFO] Eclipse SmartHome Configuration Dispatcher ......... SUCCESS [ 11.178 s]
[INFO] Eclipse SmartHome Configuration Dispatcher Tests ... SUCCESS [ 10.963 s]
[INFO] Eclipse SmartHome Configuration Core Tests ......... SUCCESS [ 33.236 s]
[INFO] Eclipse SmartHome Configuration Discovery .......... SUCCESS [ 12.147 s]
[INFO] Eclipse SmartHome mDNS Service ..................... SUCCESS [ 8.107 s]
[INFO] Eclipse SmartHome Configuration mDNS Discovery ..... SUCCESS [ 7.294 s]
[INFO] Eclipse SmartHome Core Thing XML ................... SUCCESS [ 11.648 s]
[INFO] Eclipse SmartHome Configuration Discovery Tests .... SUCCESS [ 16.225 s]
[INFO] Eclipse SmartHome Configuration UPnP Discovery ..... SUCCESS [ 9.112 s]
[INFO] Eclipse SmartHome Configuration Serial ............. SUCCESS [ 7.355 s]
[INFO] Eclipse SmartHome Config XML Tests ................. SUCCESS [ 11.363 s]
[INFO] Eclipse SmartHome Core Audio ....................... SUCCESS [ 11.707 s]
[INFO] Eclipse SmartHome Core Binding XML ................. SUCCESS [ 10.042 s]
[INFO] Eclipse Smarthome Audio Test ....................... SUCCESS [ 12.513 s]
[INFO] Eclipse SmartHome Sample Extension Service ......... SUCCESS [ 7.068 s]
[INFO] Eclipse SmartHome REST Interface ................... SUCCESS [ 9.384 s]
[INFO] Eclipse SmartHome Core ID .......................... SUCCESS [ 6.882 s]
[INFO] Eclipse SmartHome ID Tests ......................... SUCCESS [ 6.697 s]
[INFO] Eclipse SmartHome Core Tests ....................... SUCCESS [ 22.315 s]
[INFO] Eclipse SmartHome Thing Tests ...................... SUCCESS [01:01 min]
[INFO] Eclipse SmartHome Core Persistence ................. SUCCESS [ 10.108 s]
[INFO] Eclipse SmartHome Core Scheduler Service ........... SUCCESS [ 6.718 s]
[INFO] Eclipse SmartHome Core Transformation Service ...... SUCCESS [ 8.123 s]
[INFO] Eclipse SmartHome Core Binding XML Tests ........... SUCCESS [ 8.793 s]
[INFO] Eclipse SmartHome Core Thing XML Tests ............. SUCCESS [ 12.924 s]
[INFO] Eclipse SmartHome Core Voice ....................... SUCCESS [ 13.189 s]
[INFO] Eclipse SmartHome Core Voice Test .................. SUCCESS [ 10.095 s]
[INFO] Eclipse SmartHome Automation ....................... SUCCESS [ 0.325 s]
[INFO] Eclipse SmartHome Automation API ................... SUCCESS [ 17.184 s]
[INFO] Eclipse SmartHome Automation Commands .............. SUCCESS [ 11.729 s]
[INFO] Eclipse SmartHome Automation Parser GSON ........... SUCCESS [ 8.326 s]
[INFO] Eclipse SmartHome Automation Providers ............. SUCCESS [ 10.373 s]
[INFO] Eclipse SmartHome Automation Provider File ......... SUCCESS [ 8.821 s]
[INFO] Eclipse SmartHome Automation Core .................. SUCCESS [ 14.281 s]
[INFO] Eclipse SmartHome Automation Core Tests ............ SUCCESS [ 10.391 s]
[INFO] Eclipse SmartHome Automation Sample JSON ........... SUCCESS [ 12.506 s]
[INFO] Eclipse SmartHome Automation Core Modules .......... SUCCESS [ 11.014 s]
[INFO] Eclipse SmartHome Automation Core Module Tests ..... SUCCESS [ 10.970 s]
[INFO] Eclipse SmartHome Automation Script Modules ........ SUCCESS [ 11.975 s]
[INFO] Eclipse SmartHome Automation Media Modules ......... SUCCESS [ 9.942 s]
[INFO] Eclipse SmartHome Automation Timer Modules ......... SUCCESS [ 9.016 s]
[INFO] Eclipse SmartHome Automation Module Timer Tests .... SUCCESS [ 11.787 s]
[INFO] Eclipse SmartHome Automation Script Default Scope .. SUCCESS [ 8.955 s]
[INFO] Eclipse SmartHome Automation Script RuleSupport .... SUCCESS [ 14.237 s]
[INFO] Eclipse SmartHome Automation Script Module Tests ... SUCCESS [ 8.148 s]
[INFO] Eclipse SmartHome Automation Event Tests ........... SUCCESS [ 8.831 s]
[INFO] Eclipse SmartHome Automation Integration Tests ..... SUCCESS [ 17.862 s]
[INFO] Eclipse SmartHome Automation Sample Extension Java . SUCCESS [ 31.702 s]
[INFO] Eclipse SmartHome Automation REST API .............. SUCCESS [ 13.702 s]
[INFO] Eclipse SmartHome Automation Sample REST API ....... SUCCESS [ 8.249 s]
[INFO] Eclipse SmartHome Automation Java Demo ............. SUCCESS [ 6.691 s]
[INFO] Eclipse SmartHome Automation Json Demo ............. SUCCESS [ 3.686 s]
[INFO] Eclipse SmartHome Automation Module Type Demo ...... SUCCESS [ 8.715 s]
[INFO] Eclipse SmartHome Console for OSGi framework Eclipse Equinox SUCCESS [ 8.704 s]
[INFO] Eclipse SmartHome Console for OSGi Console RFC 147 . SUCCESS [ 11.014 s]
[INFO] Eclipse SmartHome Console for OSGi runtime Karaf ... SUCCESS [ 8.961 s]
[INFO] Eclipse SmartHome Monitor .......................... SUCCESS [ 7.825 s]
[INFO] Eclipse SmartHome Network I/O ...................... SUCCESS [ 11.033 s]
[INFO] Eclipse SmartHome Network I/O Tests ................ SUCCESS [ 8.698 s]
[INFO] Eclipse SmartHome IO REST Tests .................... SUCCESS [ 10.727 s]
[INFO] Eclipse SmartHome Authentication Support for the REST Interface SUCCESS [ 9.220 s]
[INFO] Eclipse SmartHome Basic Auth for the REST Interface SUCCESS [ 9.346 s]
[INFO] Eclipse SmartHome Core REST Interface .............. SUCCESS [ 22.005 s]
[INFO] Eclipse SmartHome IO REST Core Tests ............... SUCCESS [ 10.904 s]
[INFO] Eclipse SmartHome REST mDNS Announcer .............. SUCCESS [ 7.868 s]
[INFO] Eclipse SmartHome REST JAX-RS Optimizations ........ SUCCESS [ 9.081 s]
[INFO] Eclipse SmartHome SSE Interface .................... SUCCESS [ 10.920 s]
[INFO] Eclipse SmartHome IO SSE Tests ..................... SUCCESS [ 9.923 s]
[INFO] Eclipse SmartHome Models ........................... SUCCESS [ 12.564 s]
[INFO] Eclipse SmartHome Model Core ....................... SUCCESS [ 20.341 s]
[INFO] Eclipse SmartHome Model Lazy Generation ............ SUCCESS [ 13.632 s]
[INFO] Eclipse SmartHome Model Sitemap .................... SUCCESS [01:18 min]
[INFO] Eclipse SmartHome Model Items ...................... SUCCESS [ 37.046 s]
[INFO] Eclipse SmartHome UIs .............................. SUCCESS [ 0.185 s]
[INFO] Eclipse SmartHome UI ............................... SUCCESS [ 20.160 s]
[INFO] Eclipse SmartHome Sitemap REST Interface ........... SUCCESS [ 13.402 s]
[INFO] Eclipse SmartHome Core REST UI Logging Module ...... SUCCESS [ 8.697 s]
[INFO] Eclipse SmartHome Voice REST Interface ............. SUCCESS [ 7.913 s]
[INFO] Eclipse SmartHome DBus Transport ................... SUCCESS [ 3.541 s]
[INFO] Eclipse SmartHome MQTT Transport ................... SUCCESS [ 11.097 s]
[INFO] Eclipse SmartHome Mqtt Transport I/O Tests ......... SUCCESS [ 8.847 s]
[INFO] Eclipse SmartHome UPnP Transport ................... SUCCESS [ 10.267 s]
[INFO] Eclipse SmartHome IO UPnP Tests .................... SUCCESS [ 14.363 s]
[INFO] Eclipse SmartHome Model Core Tests ................. SUCCESS [ 12.066 s]
[INFO] Eclipse SmartHome Model Item IDE ................... SUCCESS [ 20.256 s]
[INFO] Eclipse SmartHome Model Items Runtime .............. SUCCESS [ 7.510 s]
[INFO] Eclipse SmartHome Items Model Tests ................ SUCCESS [ 12.833 s]
[INFO] Eclipse SmartHome Model Persistence ................ SUCCESS [ 34.809 s]
[INFO] Eclipse SmartHome Model Persistence IDE ............ SUCCESS [ 15.052 s]
[INFO] Eclipse SmartHome Model Script ..................... SUCCESS [01:09 min]
[INFO] Eclipse SmartHome Model Rules ...................... SUCCESS [01:13 min]
[INFO] Eclipse SmartHome Model Rule IDE ................... SUCCESS [ 34.347 s]
[INFO] Eclipse SmartHome Model Script IDE ................. SUCCESS [ 35.482 s]
[INFO] Eclipse SmartHome Model Sitemap IDE ................ SUCCESS [ 41.291 s]
[INFO] Eclipse SmartHome Thing Model ...................... SUCCESS [ 50.127 s]
[INFO] Eclipse SmartHome Model Thing IDE .................. SUCCESS [ 20.775 s]
[INFO] Eclipse SmartHome Language Server .................. SUCCESS [ 13.483 s]
[INFO] Eclipse SmartHome Language Server Tests ............ SUCCESS [ 9.503 s]
[INFO] Eclipse SmartHome Model Persistence Runtime ........ SUCCESS [ 7.827 s]
[INFO] Eclipse SmartHome Model Persistence Tests .......... SUCCESS [ 14.185 s]
[INFO] Eclipse SmartHome Model Rules Runtime .............. SUCCESS [ 17.648 s]
[INFO] Eclipse SmartHome Model Rules Tests ................ SUCCESS [ 6.274 s]
[INFO] Eclipse SmartHome Model Script Runtime ............. SUCCESS [ 16.186 s]
[INFO] Eclipse SmartHome Model Script Tests ............... SUCCESS [ 12.699 s]
[INFO] Eclipse SmartHome Model Sitemap Runtime ............ SUCCESS [ 9.000 s]
[INFO] Eclipse SmartHome Thing Model Runtime .............. SUCCESS [ 8.968 s]
[INFO] Eclipse SmartHome Thing Model Tests ................ SUCCESS [ 23.066 s]
[INFO] Eclipse SmartHome UI Tests ......................... SUCCESS [ 11.394 s]
[INFO] Eclipse SmartHome UI Icon Support .................. SUCCESS [ 11.841 s]
[INFO] Eclipse SmartHome UI Icon Tests .................... SUCCESS [ 27.200 s]
[INFO] Eclipse SmartHome Storages ......................... SUCCESS [ 0.250 s]
[INFO] Eclipse SmartHome JSON Storage ..................... SUCCESS [ 11.483 s]
[INFO] Eclipse SmartHome Storage JSON Tests ............... SUCCESS [ 10.918 s]
[INFO] Eclipse SmartHome MapDB Storage .................... SUCCESS [ 12.871 s]
[INFO] Eclipse SmartHome Storage MapDB Tests .............. SUCCESS [ 12.082 s]
[INFO] Eclipse SmartHome Extensions ....................... SUCCESS [ 0.497 s]
[INFO] Eclipse SmartHome Bindings ......................... SUCCESS [ 0.278 s]
[INFO] Eclipse SmartHome Astro Binding .................... SUCCESS [ 25.644 s]
[INFO] Eclipse SmartHome Astro Binding Tests .............. SUCCESS [ 14.253 s]
[INFO] Eclipse SmartHome DigitalSTROM Binding ............. SUCCESS [ 47.285 s]
[INFO] Eclipse Smarthome DMX Binding ...................... SUCCESS [ 17.148 s]
[INFO] Eclipse Smarthome DMX Binding Tests ................ SUCCESS [ 14.746 s]
[INFO] Eclipse SmartHome hue Binding ...................... SUCCESS [ 35.609 s]
[INFO] Eclipse SmartHome hue Binding Tests ................ SUCCESS [ 20.936 s]
[INFO] Eclipse SmartHome FSInternetRadio Binding .......... SUCCESS [ 15.651 s]
[INFO] Eclipse Smarthome FSInternetRadio Binding Test ..... SUCCESS [ 14.608 s]
[INFO] Eclipse SmartHome LIFX Binding ..................... SUCCESS [ 25.376 s]
[INFO] Eclipse SmartHome LIRC Binding ..................... SUCCESS [ 15.524 s]
[INFO] Eclipse SmartHome NTP Binding ...................... SUCCESS [ 14.268 s]
[INFO] Eclipse SmartHome NTP Binding Tests ................ SUCCESS [ 16.761 s]
[INFO] SerialButton Binding ............................... SUCCESS [ 12.739 s]
[INFO] Eclipse SmartHome Sonos Binding .................... SUCCESS [ 27.864 s]
[INFO] TRÅDFRI Binding .................................... SUCCESS [ 24.371 s]
[INFO] TRÅDFRI Binding Tests .............................. SUCCESS [ 16.441 s]
[INFO] WeatherUnderground Binding ......................... SUCCESS [ 22.615 s]
[INFO] Eclipse SmartHome WeMo Binding ..................... SUCCESS [ 16.864 s]
[INFO] Eclipse SmartHome Wemo Binding Tests ............... SUCCESS [ 30.061 s]
[INFO] Eclipse SmartHome YahooWeather Binding ............. SUCCESS [ 16.290 s]
[INFO] Eclipse SmartHome Extension Service Extensions ..... SUCCESS [ 0.174 s]
[INFO] Eclipse SmartHome IoT Marketplace Extension Service SUCCESS [ 18.225 s]
[INFO] Eclipse SmartHome IoT Marketplace Extension Automation Support SUCCESS [ 14.780 s]
[INFO] Eclipse SmartHome IoT Marketplace Extension Service Test SUCCESS [ 11.646 s]
[INFO] Eclipse SmartHome I/O Services ..................... SUCCESS [ 1.024 s]
[INFO] Eclipse SmartHome JavaSound I/O .................... SUCCESS [ 13.175 s]
[INFO] Eclipse SmartHome Web Audio Support ................ SUCCESS [ 12.162 s]
[INFO] Eclipse SmartHome Transformation Services .......... SUCCESS [ 0.245 s]
[INFO] Eclipse SmartHome Exec Transformation Service ...... SUCCESS [ 9.753 s]
[INFO] Eclipse SmartHome Javascript Transformation Service SUCCESS [ 9.522 s]
[INFO] Eclipse SmartHome Map Transformation Service ....... SUCCESS [ 12.475 s]
[INFO] Eclipse SmartHome Map Transformation Service Tests . SUCCESS [ 13.442 s]
[INFO] Eclipse SmartHome Scale Transformation Service ..... SUCCESS [ 13.106 s]
[INFO] Eclipse SmartHome Scale Transformation Service Tests SUCCESS [ 11.957 s]
[INFO] Eclipse SmartHome RegEx Transformation Service ..... SUCCESS [ 37.658 s]
[INFO] Eclipse SmartHome RegEx Transformation Service Tests SUCCESS [ 14.003 s]
[INFO] Eclipse SmartHome XPath Transformation Service ..... SUCCESS [ 9.590 s]
[INFO] Eclipse SmartHome XPath Transformation Service Tests SUCCESS [ 9.511 s]
[INFO] Eclipse SmartHome JSonPath Transformation Service .. SUCCESS [ 11.287 s]
[INFO] Eclipse SmartHome JSonPath Transformation Service Tests SUCCESS [ 8.460 s]
[INFO] Eclipse SmartHome Xslt Transformation Service ...... SUCCESS [ 12.223 s]
[INFO] Eclipse SmartHome Xslt Transformation Service Tests SUCCESS [ 10.041 s]
[INFO] Eclipse SmartHome UI Extensions .................... SUCCESS [ 0.171 s]
[INFO] Eclipse SmartHome Icon Sets ........................ SUCCESS [ 0.122 s]
[INFO] Eclipse SmartHome Classic Icon Set ................. SUCCESS [ 29.392 s]
[INFO] Eclipse SmartHome Basic UI ......................... SUCCESS [02:01 min]
[INFO] Eclipse SmartHome Classic UI ....................... SUCCESS [ 21.770 s]
[INFO] Eclipse SmartHome Paper UI ......................... FAILURE [05:33 min]
[INFO] Eclipse SmartHome Voice Services ................... SKIPPED
[INFO] Eclipse SmartHome MacOS TTS ........................ SKIPPED
[INFO] Eclipse SmartHome Mac TTS Tests .................... SKIPPED
[INFO] Eclipse SmartHome Features ......................... SKIPPED
[INFO] Eclipse SmartHome Runtime Core Feature ............. SKIPPED
[INFO] Eclipse SmartHome Runtime Model Feature ............ SKIPPED
[INFO] Eclipse SmartHome Runtime UI Feature ............... SKIPPED
[INFO] Eclipse SmartHome Runtime REST Feature ............. SKIPPED
[INFO] Eclipse SmartHome Runtime Automation Feature ....... SKIPPED
[INFO] Eclipse SmartHome Runtime Equinox Console Feature .. SKIPPED
[INFO] Eclipse SmartHome Runtime RfC147 Console Feature ... SKIPPED
[INFO] Eclipse SmartHome Runtime Binding Feature .......... SKIPPED
[INFO] Eclipse SmartHome Test Dependencies ................ SKIPPED
[INFO] Eclipse SmartHome Karaf Features ................... SKIPPED
[INFO] Eclipse SmartHome Target Platform Feature .......... SKIPPED
[INFO] Eclipse SmartHome Core Feature ..................... SKIPPED
[INFO] Eclipse SmartHome Extensions Feature ............... SKIPPED
[INFO] Eclipse SmartHome Karaf Feature Verification ....... SKIPPED
[INFO] Eclipse SmartHome Products ......................... SKIPPED
[INFO] Eclipse SmartHome p2 Repository .................... SKIPPED
[INFO] Eclipse SmartHome Tools ............................ SKIPPED
[INFO] Eclipse SmartHome Archetypes ....................... SKIPPED
[INFO] Eclipse Smarthome Binding Archetype ................ SKIPPED
[INFO] Eclipse Smarthome Binding Archetype Testsuite ...... SKIPPED
[INFO] Eclipse SmartHome Target Platform .................. SKIPPED
[INFO] Eclipse SmartHome Distribution ..................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 55:10 min
[INFO] Finished at: 2018-01-25T12:13:46+05:30
[INFO] Final Memory: 391M/931M
[ERROR] Failed to execute goal com.github.eirslett:frontend-maven-plugin:1.0:npm (npm install) on project org.eclipse.smarthome.ui.paper: Failed to run task: 'npm install' failed. (error code 1) -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR] mvn <goals> -rf :org.eclipse.smarthome.ui.paper
FUDForum. Page generated in 0.03669 seconds
