Re: Kura 3.1.0, Raspi3, Sensortag connectivity Problem [message #1780068 is a reply to message #1779965] |
Wed, 17 January 2018 04:28 |
Adrian Lim Messages: 5 Registered: January 2018 |
Junior Member |
Hi Pier,
thanks for your help as now it is partially working!
the sensortag green led is blinking when kura was trying to connect to the device. I removed the battery on the sensortag and reinserted and now it works in that kura.log reports the values are being read from the sensortag.
However, in the "Drivers and Assets" section of the Kura web page, when i try to read the device Data I get an "org.eclipse.kura.web.client.ui.EntryClassUi: A generic unrecoverable error happened. Please refer to the device log"
kura.log has the below
org.eclipse.kura.KuraBluetoothDiscoveryException: Error during discovery procedure.
at org.eclipse.kura.internal.ble.BluetoothLeAdapterImpl$BluetoothFuture.run(BluetoothLeAdapterImpl.java:232)
... 1 more
2018-01-16 20:22:05,862 [qtp23450296-108] WARN o.e.k.i.d.b.s.SensorTagDriver - SensortTag Read Operation Failed
2018-01-16 20:22:10,831 [Thread-489] ERROR o.e.k.i.b.BluetoothLeAdapterImpl - Stop discovery failed
tinyb.BluetoothException: GDBus.Error:org.bluez.Error.Failed: No discovery started
at tinyb.BluetoothAdapter.stopDiscovery(Native Method)
at org.eclipse.kura.internal.ble.BluetoothLeAdapterImpl$BluetoothFuture.run(BluetoothLeAdapterImpl.java:249)
at java.lang.Thread.run(Thread.java:745)
2018-01-16 20:22:10,834 [Thread-490] ERROR o.e.k.i.b.BluetoothLeAdapterImpl - Stop discovery failed
the sensortag data like temperature etc is being written to the log so the problem is now on the "UI" level data discovery.
So almost there!....any pointers on this?
rgds adrian
[Updated on: Wed, 17 January 2018 05:30] Report message to a moderator
FUDForum. Page generated in 0.03427 seconds
