Re: Provider org.apache.tomcat.websocket.server.DefaultServerEndpointConfigurator not found [message #1778756 is a reply to message #1778508] |
Wed, 20 December 2017 23:12 |
Violeta Georgieva Messages: 11 Registered: October 2016 |
Junior Member |
Lukas Höllein wrote on Fri, 15 December 2017 12:26Hi Dani,
ok I attached some files.
I hope this helps you to better unterstand my problem.
I have two bundles:
1. Server - requires websocket. Consists of "server-pom.xml", "server-Activator.java"
2. websocket. Consists of "websocket-pom.xml", "EndpointPublisher.java", "WebSocketServlet.java"
The error occurs, when trying to start the "Server" bundle via its activator.
In its activator, the "websocket" bundle is referenced.
In "WebSocketServlet" I created a comment starting with "$ERROR_HERE$".
Thats the line of code where the last code of me gets executed before the "Provider not found" error.
Thanks for your help,
Lukas
Why do you try to provide your own server? Is there any requirement about that?
Virgo Server for Apache Tomcat supports websockets.
Violeta
FUDForum. Page generated in 0.03343 seconds
