execute shell not working on Hudson 3.3.3 [message #1775472] |
Mon, 30 October 2017 15:46 |
Tarak Chadaram Messages: 5 Registered: January 2017 |
Junior Member |
Under the build category in the configuration, there is a execute shell command text box.When selected and test shell command build not executing the commands.
Do I miss anything to run the shell command? I installed the post plugin to run the shell command.
FYI we have Hudson 3.2.2 and shell commands working with no issues. However, we Can't use 3.2.2 as per project plan and moved to 3.3.3
Last few lines of the log
[workspace] $ /oraapp/tfs/TEE-CLC-12.0.2/tf history $/CSSIntegrationHub/BuildScripts/OSB -noprompt -version:D2017-10-30T15:19:06Z~D2017-10-30T15:22:48Z -recursive -format:detailed -server:http://tfs.southernco.com:8080/tfs/CSS ********
( Suppose to execute shell command but for now its not working)
No history entries were found for the item and version combination specified.
[DEBUG] Skipping watched dependency update; build not configured with trigger: Promote_CommonResources_Cust #10
Notifying upstream projects of job completion
Finished: SUCCESS
Appreciate for the help.
Tarak.
FUDForum. Page generated in 0.03314 seconds
