Home » Archived » Lua Development Tools » Debugger process was unexpectedly terminated with custom Lua 5.1 on Windows 10(Not possible to debug in LDT on Windows 10 with a customer Lua 5.1 build)
Debugger process was unexpectedly terminated with custom Lua 5.1 on Windows 10 [message #1772764] Thu, 14 September 2017 21:46 Go to next message
Pascal Collberg is currently offline Pascal CollbergFriend
Hi!
I have compiled an official version of Lua (5.1.4) fetched from here:
sourceforge.net/projects/luabinaries/files/5.1.4/Docs%20and%20Sources/lua5_1_4_Sources.zip/download
on a Windows 10 machine using this script:
cl /MD /O2 /c /DLUA_BUILD_AS_DLL *.c
link /DLL /IMPLIB:lua5.1.lib /OUT:lua5.1.dll *.obj
mv lua.obj lua.o
link /OUT:lua.exe lua.o lua5.1.lib /DYNAMICBASE "c:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.10.25017\lib\x86\legacy_stdio_definitions.lib"
When I add this customer lua exe as an interpreter to my LDT installation and try to debug a very simple script (just a print of hello world) I get the following error:
'Debugger process was unexpectedly terminated'
If I "Enable DBGP logging" I can see these printouts:
CREATE from org.eclipse.ldt.debug.core.internal.LuaDebugTarget
MODEL_SPECIFIC/1 from org.eclipse.dltk.launching.InterpreterConfig
CHANGE from org.eclipse.dltk.launching.process.ScriptRuntimeProcess
CREATE from org.eclipse.dltk.launching.process.ScriptRuntimeProcess
TERMINATE from org.eclipse.dltk.launching.process.ScriptRuntimeProcess
TERMINATE from org.eclipse.ldt.debug.core.internal.LuaDebugTarget
I used to do exactly the same on Windows 7 before I upgraded to Windows 10 and then it all worked fine.
Does anybody know what might be wrong?
Thanks!
/Pascal
Re: Debugger process was unexpectedly terminated with custom Lua 5.1 on Windows 10 [message #1772845 is a reply to message #1772764] Sun, 17 September 2017 07:39 Go to previous message
Hi again,
It turned out that I had not configured my LuaRocks properly.
LDT was missing lua_cpath and lua_path variables to find all required dependencies.
Previous Topic:remote development: csv and other file extensions filter
Next Topic:Running application error
Current Time: Fri May 03 21:20:33 GMT 2024
Powered by FUDForum. Page generated in 0.02167 seconds
