Sudden Build Problem [message #1772433] |
Sat, 09 September 2017 15:13 |
Jabba Loon Messages: 11 Registered: August 2017 |
Junior Member |
Hi All,
I am sure I am going to kick myself when I figure out what is wrong, but have been trying for the last few hours and cannot find a solution!
Basically, I was in the middle of developing a binding and had made good progress. Was partially working etc....
Then I went away on vacation for a few weeks. When I came back, I launched Eclipse, ready to resume and all of a sudden nothing is compiling at all. Every single plugin is failing to build!
I saw elsewhere that I should try to run the setup tasks from the Help menu and did this 5-6 times with no impact. However, I did notice the following in the output from the setup task:
Performing Target Platform openHAB Target Platform
Calculating requirements and dependencies.
Cannot complete the request. Generating details.
Performing Projects Import
The errors in relation to the build failing look like something is misconfigured in relation to dependancies as they are all relating to unable to find imports etc.. for example "BaseThingHandler" cannot be resolved to a type etc...
I have tried clean build and have tried performing the setup task several times, but nothing makes a difference. I havent changed anything since all was working a few weeks ago, so am at a bit of a loss as to where to look next!!!
Any ideas?
Jabba
FUDForum. Page generated in 0.10195 seconds
