[Teneo] Problem with Enumerated Key in EMap [message #1772402] |
Fri, 08 September 2017 15:33 |
Patric Bayer Messages: 3 Registered: September 2015 |
Junior Member |
I have several EMaps in my model with Enumerated Keys. There is some commented code in class "OneToManyReferenceAnnotator" which says, that this is intentionally commented as Hibernate does not support Enumerated keys. Therefore, not table is set up for my EMaps and they cannot be persisted.
Any suggestions how to deal with this problem? This is only a problem if I set "EMap as True Map" true, but if I set it false there seem to be a not to little performance issue with the EMaps.
Maybe this is already solved in the current version? On Teneo wiki is a version from 2017, but I cannot find this in the maven repository (there is the last from 2015).
Thank you for your help
Patric
[Updated on: Fri, 08 September 2017 15:35] Report message to a moderator
FUDForum. Page generated in 0.03054 seconds
