ShellEd: Outline is gone! [message #1767378] |
Wed, 05 July 2017 12:33 |
Chris Barlock Messages: 32 Registered: July 2009 |
Member |
Since upgrading to ShellEd 5.8.0, the Outline view of my scripts is gone! One of the most valuable features of the editor. :-( All I see is an icon of a white 'C' in a green circle and the name of the script. If I right click on this entry in the Outline view, I get this in the error log:
com.ibm.team.filesystem.client.FileSystemException: Resource '/ /start-mongodb.sh' does not exist.
at com.ibm.team.filesystem.client.internal.copyfileareas.CopyFileAreaUtil.isShareRoot(CopyFileAreaUtil.java:179)
at com.ibm.team.filesystem.ide.ui.internal.util.NestedLoadPropertyTester.test(NestedLoadPropertyTester.java:35)
at org.eclipse.core.internal.expressions.Property.test(Property.java:58)
at org.eclipse.core.internal.expressions.TestExpression.evaluate(TestExpression.java:100)
at org.eclipse.core.internal.expressions.CompositeExpression.evaluateAnd(CompositeExpression.java:53)
at org.eclipse.core.internal.expressions.EnablementExpression.evaluate(EnablementExpression.java:55)
at org.eclipse.ui.internal.ObjectActionContributor$ObjectContribution.isApplicableTo(ObjectActionContributor.java:368)
at org.eclipse.ui.internal.ObjectActionContributor.isApplicableTo(ObjectActionContributor.java:238)
at org.eclipse.ui.internal.ObjectContributorManager.isApplicableTo(ObjectContributorManager.java:302)
at org.eclipse.ui.internal.ObjectActionContributorManager.contributeObjectActions(ObjectActionContributorManager.java:89)
at org.eclipse.ui.internal.PopupMenuExtender.addObjectActions(PopupMenuExtender.java:317)
at org.eclipse.ui.internal.PopupMenuExtender.menuAboutToShow(PopupMenuExtender.java:394)
at org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuManager.java:339)
at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:470)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:465)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:497)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:256)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1103)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1084)
at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.java:5160)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4828)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:359)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1656)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2199)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5110)
at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:262)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:4277)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3818)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:95)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55)
at java.lang.reflect.Method.invoke(Method.java:508)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: org.eclipse.core.internal.resources.ResourceException: Resource '/ /start-mongodb.sh' does not exist.
at org.eclipse.core.internal.resources.Resource.checkExists(Resource.java:335)
at org.eclipse.core.internal.resources.Resource.checkAccessible(Resource.java:209)
at org.eclipse.core.internal.resources.Resource.checkAccessibleAndLocal(Resource.java:215)
at org.eclipse.core.internal.resources.Resource.getPersistentProperty(Resource.java:1151)
at com.ibm.team.filesystem.client.internal.copyfileareas.CopyFileAreaUtil.isShareRoot(CopyFileAreaUtil.java:175)
... 53 more
I presume I should open a bug report, but thought I'd start here first.
[Updated on: Wed, 05 July 2017 19:36] Report message to a moderator
FUDForum. Page generated in 0.03279 seconds
