Home » Eclipse Projects » Eclipse Platform » Syntax Coloring in Wizard Previewer
Syntax Coloring in Wizard Previewer [message #332106] Fri, 03 October 2008 09:09 Go to next message
I have an eclipse based editor, which has a project and file wizard. My
file wizard allows a user to create a script or choose an already
available script in the form of templates available. These templates are
displayed in a previewer in the wizard. My question is..is there some way
to apply syntax highlighting to the code visible in the previewer?
Thanks in Advance
Sheela
Re: Syntax Coloring in Wizard Previewer [message #332120 is a reply to message #332106] Mon, 06 October 2008 06:02 Go to previous messageGo to next message
Sheela wrote:
> My file wizard allows a user to create a script or choose an already
> are displayed in a previewer in the wizard. My question is..is there
> some way to apply syntax highlighting to the code visible in the
> previewer?
Sure. You can use a source viewer and configure it with a source viewer
configuration that returns your presentation reconciler.
Dani
> Thanks in Advance
> Sheela
Re: Syntax Coloring in Wizard Previewer [message #332164 is a reply to message #332120] Wed, 08 October 2008 01:27 Go to previous message
Thanks for your reply Dani,
Previous Topic:Invalid links on web page
Next Topic:Adding plugins through natures?
Current Time: Tue Nov 18 20:20:38 EST 2025
Powered by FUDForum. Page generated in 0.06164 seconds
