Home » Archived » Eclipse SmartHome » OSGI bundle Exception : Unable to resolve binding(org.osgi.framework.BundleException: Unable to resolve org.openhab.binding.snavxbee2)
OSGI bundle Exception : Unable to resolve binding [message #1764773] |
Fri, 02 June 2017 08:47 |
AMAR PULLI Messages: 7 Registered: February 2017 |
Junior Member |
I am trying to load one jar file of bundle into Eclipse Smart Home. I did followed below link to get that ESH repository .
https://github.com/maggu2810/smarthome-packaging-sample-karaf
Here I just clone the repo and calll "mvn clean install" after cloning has been completed ,will get full repository. I am trying to build jar file bundle here,
https://github.com/g1velo/SNAVXbee2/tree/master/org.openhab.binding.snavxbee2
Then we could drop the jar file of bundle into target/assembly/deploy folder location.
When I start the Eclipse smart home , the bundle is not going to active state see below my bundle status. It will show only installed
95 | Active | 80 | 5.0.2 | Require-Bundle Fix :: org.objectweb.asm
201 | Active | 80 | 2.1.0.201704141547 | HABPanel User Interface
202 | Active | 80 | 2.0.0.b3 | openHAB Dashboard UI
204 | Active | 80 | 2.0.0.b3 | openHAB Serial Transport Bundle
206 | Installed | 80 | 2.0.2.201706011411 | SNAVXbee2 Binding
Error log file:
2017-06-01 14:12:57,820 | ERROR | lixDispatchQueue | snavxbee2 | 206 - org.openhab.binding.snavxbee2 - 2.0.2.201706011411 | FrameworkEvent ERROR - org.openhab.binding.snavxbee2
org.osgi.framework.BundleException: Unable to resolve org.openhab.binding.snavxbee2 [206](R 206.0): missing requirement [org.openhab.binding.snavxbee2 [206](R 206.0)] osgi.wiring.package; (osgi.wiring.package=org.openhab.core.items) Unresolved requirements: [[org.openhab.binding.snavxbee2 [206](R 206.0)] osgi.wiring.package; (osgi.wiring.package=org.openhab.core.items)]
at org.apache.felix.framework.Felix.resolveBundleRevision(Felix.java:4111)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.Felix.startBundle(Felix.java:2117)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.Felix.setActiveStartLevel(Felix.java:1371)[org.apache.felix.framework-5.4.0.jar:]
at org.apache.felix.framework.FrameworkStartLevelImpl.run(FrameworkStartLevelImpl.java:308)[org.apache.felix.framework-5.4.0.jar:]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
This is the My Manifest file:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: SNAVXbee2 Binding
Bundle-SymbolicName: org.openhab.binding.snavxbee2;singleton:=true
Bundle-Vendor: openHAB
Bundle-Version: 2.0.2.qualifier
Bundle-RequiredExecutionEnvironment: JavaSE-1.7
Bundle-ClassPath: .
Import-Package:
com.google.common.collect;version="10.0.1",
gnu.io,
org.eclipse.smarthome.config.core,
org.eclipse.smarthome.config.discovery,
org.eclipse.smarthome.core.common.registry,
org.eclipse.smarthome.core.items,
org.eclipse.smarthome.core.library.types,
org.eclipse.smarthome.core.thing,
org.eclipse.smarthome.core.thing.binding,
org.eclipse.smarthome.core.thing.binding.builder,
org.eclipse.smarthome.core.thing.type,
org.eclipse.smarthome.core.transform.actions,
org.eclipse.smarthome.core.types,
org.jupnp.model.meta,
org.openhab.binding.snavxbee2,
org.openhab.binding.snavxbee2.handler,
org.openhab.core.items,
org.osgi.framework;version="1.8.0",
org.slf4j
Service-Component: OSGI-INF/*.xml
Export-Package: com.digi.xbee.api;
uses:="com.digi.xbee.api.connection.serial,
org.slf4j,
com.digi.xbee.api.connection,
com.digi.xbee.api.models,
com.digi.xbee.api.listeners,
com.digi.xbee.api.io,
com.digi.xbee.api.packet",
com.digi.xbee.api.connection;
uses:="com.digi.xbee.api.models,
com.digi.xbee.api,
com.digi.xbee.api.connection.serial;uses:="gnu.io,com.digi.xbee.api.connection",
com.digi.xbee.api.discoverdevices;uses:="com.digi.xbee.api.listeners,com.digi.xbee.api",
com.digi.xbee.api.exceptions;uses:="com.digi.xbee.api.models",
com.digi.xbee.api.listeners;
com.digi.xbee.api.packet,
com.digi.xbee.api",
com.digi.xbee.api.models;uses:="com.digi.xbee.api,com.digi.xbee.api.packet",
com.digi.xbee.api.packet;uses:="com.digi.xbee.api.models",
com.digi.xbee.api.packet.common;uses:="com.digi.xbee.api.models,com.digi.xbee.api.io,com.digi.xbee.api.packet",
com.digi.xbee.api.packet.raw;uses:="com.digi.xbee.api.models,com.digi.xbee.api.io,com.digi.xbee.api.packet",
com.digi.xbee.api.utils,
org.openhab.binding.snavxbee2;uses:="org.eclipse.smarthome.core.thing",
org.openhab.binding.snavxbee2.handler;uses:="org.eclipse.smarthome.core.thing,org.eclipse.smarthome.core.thing.binding,org.eclipse.smarthome.core.types",
org.openhab.binding.snavxbee2.internal;x-internal:=true,
org.openhab.binding.snavxbee2.utils
Please let me know how i could resolve this issue.
Thanks and Regards
Amar.
Current Time: Thu May 02 04:02:37 GMT 2024
Powered by FUDForum. Page generated in 0.03302 seconds
