Re: Openhab-cloud connecter for ESH [message #1764885 is a reply to message #1764535] |
Fri, 02 June 2017 20:37 |
Hans-Jörg Merk Messages: 2 Registered: October 2015 |
Junior Member |
Kiran Patil wrote on Wed, 31 May 2017 05:24Hi Dan,
The openhab-cloud connector is, as the name implies, for openHAB and not for ESH as mentioned earlier by Mr. Stefan.
I would like to know from ESH community members, since IMHO this is specific to ESH not Openhab.
I guess, you are building a solution on top of ESH, similar to openHAB.
If this is the case, you should even build you own cloud service and cloud connector, as myopenHAB or openHAB-cloud-connector is only meant to be used within openhab, not for other services based on ESH.
You can get inspiration on how to build such a solution by checking the openHAB-cloud-connector sources on github.
FUDForum. Page generated in 0.03610 seconds
