Virgo 3.7.0 Fragment host, resource loading fails with JSF 2.2 [message #1761832] |
Thu, 11 May 2017 15:27 |
Joel Traber Messages: 11 Registered: October 2015 |
Junior Member |
We try to migrate a web application (Virgo 3.6.4, Spring 3.2.5, JSF 2.1, Primefaces 3.5) to Virgo 3.7.0, JSF 2.2, Primefaces 6.0.
We use the Fragment-Host feature to load web resources from another bundle. The main web application works like a host bundle. The other bundle works as a fragement bundle and provides webpages (*.xhtml). It works very smooth with Virgo 3.6.4.
The resource loading of the fragement bundles does not to work in the new environment (Virgo 3.7.0, Spring 4.2.9, JSF 2.2, Primefaces 6)
(The exception is a javax.faces.view.facelets.TagAttributeException: Invalid path : ....)
JSF is not able to retrieve the .xhtml resource. (We work on a small example to sort out that the JSF upgrade is responsible for)
Has there been a change in Virgo 3.7.0 related with the Fragment-Host feature? Or does Gemini Web 3.0 bring some changes to it?
Anybody facing something similiar?
We use Virgo 3.7.0 (virgo-tomcat-server-3.7.1.D-20170508083732) provided by Violeta Georgieva (https://bugs.eclipse.org/bugs/show_bug.cgi?id=514227)
https://hudson.eclipse.org/virgo/view/3.7.0-SNAPSHOT/job/gradle-build/lastSuccessfulBuild/artifact/packaging/tomcat-server/build/distributions/virgo-tomcat-server-latest.zip
Thanks for hints,
Joël
FUDForum. Page generated in 0.03227 seconds
