Re: [EMFStore]: How do you extend loginService [message #1761371 is a reply to message #1760917] |
Wed, 10 May 2017 09:38 |
Edgar Mueller Messages: 17 Registered: March 2016 |
Junior Member |
Hi Amalia,
you can not customize the LoginService directly but rather how it will be parameterized during construction. which you can do via the org.eclipse.emf.emfstore.server.accessContorl extension point.
That extension point has 4 different elements:
- orgUnitProvider is responsible for obtaining organizational units, i.e. users and groups
- userVerifierServiceProvider is responsible for verifying the credentials of a user, e.g. via a properties file or LDAP
- authorizationServiceProvider is responsible for authorizing certain actions
- orgUnitResolverProvider allows you to influence the resolution process of org units
For each of these elements there are default implementations, which will be used in case you don't specify any implementation.
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Edgar Mueller
[Updated on: Wed, 10 May 2017 09:42] Report message to a moderator
FUDForum. Page generated in 0.02434 seconds
