Build failed.. git project.. help me~~~ [message #1759368] |
Tue, 11 April 2017 04:34 |
JEONG GONG Messages: 1 Registered: April 2017 |
Junior Member |
Hello everyone,
I am using Hudson 3.2.1-RC1.
Can I import and build a source file from git server for windows, Called 'Bonobo git'?
I don't know what to do when the following error occurs.
___________________________________________________________________________
Started by user anonymous
Checkout:workspace / /jeus/.hudson/jobs/test-methodia/workspace - hudson.remoting.LocalChannel@70ae70ae
Using strategy: Default
Git Exe: git
Fetching changes from the remote Git repository
Fetching upstream changes from http://10.10.1.66:9090/git/mc_project.git
ERROR: Problem fetching from origin / origin - could be unavailable. Continuing anyway
hudson.plugins.git.GitException: Error performing command: git fetch -t http://10.10.1.66:9090/git/mc_project.git +refs/heads/*:refs/remotes/origin/*
Command "git fetch -t http://10.10.1.66:9090/git/mc_project.git +refs/heads/*:refs/remotes/origin/*" returned status code 255: Could not load program git:
Dependent module /usr/lib/libcrypto.a(libcrypto.so.1.0.2) could not be loaded.
Member libcrypto.so.1.0.2 is not found in archive
at hudson.plugins.git.GitAPI.launchCommandIn(GitAPI.java:785)
at hudson.plugins.git.GitAPI.launchCommand(GitAPI.java:747)
at hudson.plugins.git.GitAPI.fetch(GitAPI.java:212)
at hudson.plugins.git.GitAPI.fetch(GitAPI.java:1001)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1805)
at hudson.plugins.git.GitSCM.access$900(GitSCM.java:107)
at hudson.plugins.git.GitSCM$3.invoke(GitSCM.java:1052)
at hudson.plugins.git.GitSCM$3.invoke(GitSCM.java:1015)
at hudson.FilePath.act(FilePath.java:793)
at hudson.FilePath.act(FilePath.java:775)
at hudson.plugins.git.GitSCM.gerRevisionToBuild(GitSCM.java:1015)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:784)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1548)
at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:607)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:518)
at hudson.model.Run.run(Run.java:1450)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:44)
at hudson.model.ResourceController.execute(ResourceController.java:82)
at hudson.model.Executor.run(Executor.java:137)
Caused by: hudson.plugins.git.GitException: Command "git fetch -t http://10.10.1.66:9090/git/mc_project.git +refs/heads/*:refs/remotes/origin/*" returned status code 255: Could not load program git:
at hudson.plugins.git.GitAPI.launchCommandIn(GitAPI.java:778)
... 18 more
ERROR: Could not fetch from any repository
FATAL: Could not fetch from any repository
hudson.plugins.git.GitException: Could not fetch from any repository
at hudson.plugins.git.GitSCM$3.invoke(GitSCM.java:1059)
Any comment is appreciated. Thank you.
FUDForum. Page generated in 0.03424 seconds
