Re: Virgo Nano shutdown.bat throws error [message #1755299 is a reply to message #1754076] |
Thu, 02 March 2017 08:49 |
Chandre Gowda Messages: 56 Registered: April 2013 |
Member |
I was trying to debug the issue. The reproducible steps are as follows,
1. Start the Virgo nano server (startup.bat) when you are at home using company's network (VPN).
2. Come to office, join the office network using office network cable or wifi.
3. Stop the virgo nano server(shutdown.bat)
This will give following error.
java.rmi.ConnectException: Connection refused to host: 10.44.124.196; nested exception is:
jaua.net.ConnectException: Connection timed out: connect
at sun.rmi.transport.tcp.TCPEndpoint.neuSocket(TCPEndpoint.jaua:619)
at sun.rmi.transport.tcp.TCPChanne1.createConnection(TCPChanne1.jaua:2§§)
at sun.rmi.transport.tcp.TCPChanne1.neuConnection(TCPChannel.jaua:282)
at sun.rmi.seruer.UnicastRef.inuoke(UnicastRef.jaua:128)
at jauax.management.remote.rmi.RMISeruerImpl_Stub.neuClient(Unknoun Source)
at jauax.management.remote.rmi.RMIConnector.getConnection(RMIConnector.jaua:2378)
at jauax.management.remote.rmi.RMIConnector.connect(RMIConnector.java:2
at jauax.management.remote.JMXConnectorPactory.connect(JMXConnectorPactory.jaua:267)
at org.ec1ipse.uivgo.nano.shutdoun.ShutdounC1ient.doshutdoun(ShutdounC1ient.jaua:64)
at org.ec1ipse.uivgo.nano.shutdoun.ShutdounC1ient.performshutdoun(ShutdounClient.jaua:50)
at org.eclipse.uivgo.nano.shutdoun.ShutdounClient.main(ShutdounC1ient.jaua:43)
Caused by: jaua.net.ConnectException: Connection timed out: connect
at jaua.net.Dua1StackPlain8ocketImpl.connectB(Natiue Method)
at jaua.net.Dua18tackP1ainSocketImpl.socketConnect(Dua18tackP1ainSocketImpl.jaua:69)
at jaua.net.flbstractP1ainSocketImp1.doConnect(flbstractPlainSocketImpl.java: 39
at jaua.net.flbstractP1ainSocketImp1.connectToflddvess(flbstractP1ainSocketImpl.jaua:28B)
at jaua.net.flbstractP1ainSocketImp1.connect(flbstractP1ainSocketImpl.java:182)
at jaua.net.Plainsocketlmpl.connect(P1ainSocketImp1.jaua:157)
at jaua.net.Sockssocketlmpl.connect(SocksSocketImp1.jaua:391)
at jaua.net.Socket.connect(Socket.jaua:579)
at sun.security.eel.SSLSocketImp1.connect(SSLSocketImp1.jaua:618)
at sun.security.ss1.SSLSocketImp1.<init>(SSLSocketImp1.java:487)
at sun.security.eel.SSLSocketPactoryImp1.createsocket(SSLSocketPactoryImp1.jaua:88)
at jauax.rmi.9:1.S:1RMIClientSocketFactory.createsocket(S:1RMIClientSocketPactory.jaua:128)
at sun.rmi.transport.tcp.TCPEndpoint.neuSocket(TCPEndpoint.jaua:613)
The IP address shown above is not valid one in office network(during shutdown of the server). I try to check the shutdownclient.java, but it has 127.0.0.1 as host address.
JMXServiceURL jmxServiceURL = new JMXServiceURL(String.format("service:jmx:rmi:///jndi/rmi://127.0.0.1:%d/jmxrmi", new Object[] { Integer.valueOf(command.getPort()) }));
I am not sure why it tries to connect to unknown IP address and how is it getting the IP address. Could somebody help me on this.
[Updated on: Thu, 02 March 2017 08:52] Report message to a moderator
FUDForum. Page generated in 0.03991 seconds
