class-Open With-WindowBuilder Editor, problem to open existing file [message #1753915] |
Sun, 12 February 2017 11:35 |
jam ov Messages: 5 Registered: February 2017 |
Junior Member |
Exception during constructor evaluation
An exception happened during evaluation of
new Composite(shell, SWT.NONE | lang.getSWTDirection())
Constructor Composite(Composite,int) was used with the parameters {<null>,0}.
Note: null values may occur when parsing complex expressions that can't be resolved at design-time.
org.eclipse.wb.internal.core.utils.exception.DesignerException: 2005 (Null as parent argument.).
Show stack trace.
Hide stack trace.
Stack trace:
org.eclipse.wb.internal.core.utils.exception.DesignerException: 307 (Exception during constructor evaluation). new Composite(shell, SWT.NONE | lang.getSWTDirection()) Composite(Composite,int) {<null>,0} org.eclipse.wb.internal.core.utils.exception.DesignerException: 2005 (Null as parent argument.).
at org.eclipse.wb.internal.core.eval.evaluators.InvocationEvaluator.createConstructorProblemException(InvocationEvaluator.java:593)
at org.eclipse.wb.internal.core.eval.evaluators.InvocationEvaluator.evaluate(InvocationEvaluator.java:268)
at org.eclipse.wb.internal.core.eval.evaluators.InvocationEvaluator.evaluate(InvocationEvaluator.java:81)
at org.eclipse.wb.core.eval.AstEvaluationEngine.evaluate0(AstEvaluationEngine.java:177)
at org.eclipse.wb.core.eval.AstEvaluationEngine.evaluate(AstEvaluationEngine.java:61)
at org.eclipse.wb.internal.core.model.JavaInfoEvaluationHelper.evaluateExpression(JavaInfoEvaluationHelper.java:630)
at org.eclipse.wb.internal.core.model.JavaInfoEvaluationHelper.evaluate(JavaInfoEvaluationHelper.java:502)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.evaluateNode(JavaInfoParser.java:1309)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.access$1(JavaInfoParser.java:1300)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$ExecutionFlowParseVisitor$3.run(JavaInfoParser.java:602)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runRethrow(ExecutionUtils.java:119)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$ExecutionFlowParseVisitor.postVisit(JavaInfoParser.java:592)
at sun.reflect.GeneratedMethodAccessor41.invoke(Unknown Source)
at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.intercept(ExecutionFlowUtils.java:399)
at org.eclipse.jdt.core.dom.ASTVisitor$$EnhancerByCGLIB$$a364d9c3.postVisit(<generated>)
at org.eclipse.jdt.core.dom.ASTNode.accept(ASTNode.java:2714)
at org.eclipse.jdt.core.dom.ASTNode.acceptChild(ASTNode.java:2759)
at org.eclipse.jdt.core.dom.VariableDeclarationFragment.accept0(VariableDeclarationFragment.java:263)
at org.eclipse.jdt.core.dom.ASTNode.accept(ASTNode.java:2711)
at org.eclipse.jdt.core.dom.ASTNode.acceptChildren(ASTNode.java:2782)
at org.eclipse.jdt.core.dom.VariableDeclarationStatement.accept0(VariableDeclarationStatement.java:267)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement0(ExecutionFlowUtils.java:354)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement(ExecutionFlowUtils.java:315)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement0(ExecutionFlowUtils.java:336)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visit(ExecutionFlowUtils.java:247)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.access$1(ExecutionFlowUtils.java:235)
at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.endVisit(ExecutionFlowUtils.java:442)
at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.intercept(ExecutionFlowUtils.java:391)
at org.eclipse.jdt.core.dom.ASTVisitor$$EnhancerByCGLIB$$a364d9c3.endVisit(<generated>)
at org.eclipse.jdt.core.dom.MethodInvocation.accept0(MethodInvocation.java:241)
at org.eclipse.jdt.core.dom.ExpressionStatement.accept0(ExpressionStatement.java:145)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement0(ExecutionFlowUtils.java:343)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visit(ExecutionFlowUtils.java:228)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visit(ExecutionFlowUtils.java:191)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parseRootMethods(JavaInfoParser.java:312)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:268)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.access$9(JavaInfoParser.java:238)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:153)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:1)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:159)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:151)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:534)
at org.eclipse.wb.internal.core.editor.DesignPage.access$9(DesignPage.java:522)
at org.eclipse.wb.internal.core.editor.DesignPage$8$1.run(DesignPage.java:449)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4821)
at org.eclipse.wb.internal.core.editor.DesignPage$8.run(DesignPage.java:446)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:481)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF_withProgress(DesignPage.java:465)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:415)
at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:381)
at org.eclipse.wb.internal.core.editor.UndoManager.activate(UndoManager.java:90)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState_True(DesignPage.java:263)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState(DesignPage.java:241)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.showPage(DefaultMultiMode.java:125)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode$1.widgetSelected(DefaultMultiMode.java:63)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1103)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1088)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:802)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3167)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1850)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:333)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
Caused by: org.eclipse.wb.internal.core.utils.exception.DesignerException: 2005 (Null as parent argument.).
at org.eclipse.wb.internal.swt.model.widgets.SwtInvocationEvaluatorInterceptor.evaluateSWT(SwtInvocationEvaluatorInterceptor.java:90)
at org.eclipse.wb.internal.swt.model.widgets.SwtInvocationEvaluatorInterceptor.evaluate(SwtInvocationEvaluatorInterceptor.java:60)
at org.eclipse.wb.internal.core.eval.evaluators.InvocationEvaluator.tryInterceptors(InvocationEvaluator.java:378)
at org.eclipse.wb.internal.core.eval.evaluators.InvocationEvaluator.evaluate(InvocationEvaluator.java:255)
... 108 more
Full context stack trace:
java.lang.Error: new Composite(shell, SWT.NONE | lang.getSWTDirection())
at org.eclipse.wb.core.eval.AstEvaluationEngine.evaluate(AstEvaluationEngine.java:71)
Caused by: org.eclipse.wb.internal.core.utils.exception.DesignerException: 307 (Exception during constructor evaluation). new Composite(shell, SWT.NONE | lang.getSWTDirection()) Composite(Composite,int) {<null>,0} org.eclipse.wb.internal.core.utils.exception.DesignerException: 2005 (Null as parent argument.).
... 105 more
... 108 more
FUDForum. Page generated in 0.03890 seconds
