Home » Eclipse Projects » Virgo » Multiple spring deployments on Virgo 3.7.M03?
Multiple spring deployments on Virgo 3.7.M03? [message #1751445] |
Tue, 10 January 2017 13:06 |
Matteo Cantarelli Messages: 30 Registered: June 2012 |
Member |
I'm trying to start migrating to Eclipse Virgo 3.7.M03 to move to Spring 4.2.x.
I'm getting a stream of Uses violation errors that we didn't have before with 3.6.4. I had to make some adjustments to migrate the spring schemas and remove the springframework libd which seems to be gone now but nothing to explain the following:
[2017-01-10 12:11:55.626] ERROR TCP Connection(2)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0002E Installation of bundle 'org.geppetto.frontend' version '0.3.3' failed. org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'org.geppetto.frontend' at version '0.3.3': Cannot resolve: org.geppetto.frontend
Resolver report:
Uses violation: <Import-Package: org.springframework.web.servlet.resource; version="0.0.0"> in bundle <org.geppetto.frontend_0.3.3[1484050304691]>
Resolver reported uses conflict for import constrained to bundle <org.springframework.webmvc> constrained bundle version range "[4.2.4.v20160512-1057,4.2.4.v20160512-1057]"
Uses violation: <Import-Package: org.springframework.context.event; version="0.0.0"> in bundle <org.geppetto.frontend_0.3.3[1484050304691]>
Found conflicts:
package 'org.springframework.core.annotation_4.2.4' in bundle 'org.springframework.core_4.2.4.v20160512-1057[60]' used by 'org.springframework.context.event_4.2.4' in bundle 'org.springframework.context_4.2.4.v20160512-1057[59]'
conflicts with 'org.springframework.core.annotation_4.2.4' in bundle 'org.springframework.core_4.2.4.v20160512-1057[91]' used by 'org.springframework.web.servlet.resource_4.2.4' in bundle 'org.springframework.webmvc_4.2.4.v20160512-1057[1484050304692]'
conflicts with 'org.springframework.core.annotation_4.2.4' in bundle 'org.springframework.core_4.2.4.v20160512-1057[91]' used by 'org.springframework.web.servlet.config.annotation_4.2.4' in bundle 'org.springframework.webmvc_4.2.4.v20160512-1057[1484050304692]'
package 'org.springframework.util_4.2.4' in bundle 'org.springframework.core_4.2.4.v20160512-1057[60]' used by 'org.springframework.context.event_4.2.4' in bundle 'org.springframework.context_4.2.4.v20160512-1057[59]'
conflicts with 'org.springframework.util_4.2.4' in bundle 'org.springframework.core_4.2.4.v20160512-1057[91]' used by 'org.springframework.web.servlet.resource_4.2.4' in bundle 'org.springframework.webmvc_4.2.4.v20160512-1057[1484050304692]'
I then decided to check the Eclipse console of a freshly download Virgo 3.7.M03 without any application deployed and after starting it I've noticed something that seems weird to me, all springframeworks artifcats are deployed twice, see screenshot attached.
Am I missing something? Is there a problem with M03?
Thanks!
Matteo
[Updated on: Tue, 10 January 2017 13:06] Report message to a moderator
Re: Multiple spring deployments on Virgo 3.7.M03? [message #1751450 is a reply to message #1751445] |
Tue, 10 January 2017 13:45 |
daniel marthaler Messages: 77 Registered: April 2012 Location: Zürich |
Member |
Matteo Cantarelli wrote on Tue, 10 January 2017 14:06
Did you add additional dependencies by your own?
The reason that you can see two artifacts of deployed of each Spring bundle comes from the fact that there is a kernel and user region. If you expand the nodes of this tree you should be able to see which is deployed to kernel and which to user region.
[Updated on: Tue, 10 January 2017 13:48] Report message to a moderator
Re: Multiple spring deployments on Virgo 3.7.M03? [message #1751454 is a reply to message #1751450] |
Tue, 10 January 2017 13:59 |
Member |
Alright, thanks.
Nothing we didn't have before, In the pom we have (with <spring.version>4.2.4.RELEASE</spring.version>):
<dependency>
<groupId>org.springframework</groupId>
<artifactId>spring-core</artifactId>
<version>${spring.version}</version>
</dependency>
<dependency>
<artifactId>spring-aspects</artifactId>
</dependency>
<dependency>
<artifactId>spring-context</artifactId>
</dependency>
<dependency>
<artifactId>spring-context-support</artifactId>
</dependency>
<dependency>
<artifactId>spring-beans</artifactId>
</dependency>
<dependency>
<artifactId>spring-web</artifactId>
</dependency>
<dependency>
<artifactId>spring-test</artifactId>
</dependency>
<dependency>
<artifactId>spring-webmvc</artifactId>
</dependency>
In the generated MANIFEST
Manifest-Version: 1.0
Bnd-LastModified: 1484049660511
Build-Jdk: 1.7.0_51
Built-By: matteocantarelli
Bundle-ClassPath: .,WEB-INF/classes
Bundle-ManifestVersion: 2
Bundle-Name: Geppetto Frontend
Bundle-SymbolicName: org.geppetto.frontend
Bundle-Version: 0.3.3
Created-By: Apache Maven Bundle Plugin
Export-Package: org.geppetto.frontend;uses:="org.springframework.context
,org.springframework.context.event";version="0.3.3",org.geppetto.fronte
nd.controllers;uses:="org.geppetto.core.data,org.geppetto.core.data.mod
el,org.apache.commons.logging,org.apache.shiro,org.springframework.bean
s.factory.annotation,org.apache.shiro.subject,org.geppetto.core.utiliti
es,org.springframework.web.bind.annotation,org.geppetto.core.manager,or
g.geppetto.core.common,org.geppetto.core.auth,org.springframework.stere
otype,com.google.gson,org.geppetto.frontend.tests,javax.servlet.http,or
g.osgi.framework,org.geppetto.model.util,org.geppetto.model.datasources
,org.geppetto.core.datasources,org.eclipse.emf.ecore,org.geppetto.core.
services.registry,org.geppetto.frontend,org.geppetto.simulation.manager
,org.geppetto.core.beans,org.geppetto.frontend.messages,com.fasterxml.j
ackson.databind,com.fasterxml.jackson.core.type,org.geppetto.core.simul
ation,org.geppetto.core.model,com.fasterxml.jackson.core,org.geppetto.m
odel,org.apache.catalina.websocket,org.apache.shiro.authc,org.apache.sh
iro.realm,javax.servlet,org.springframework.http.converter,org.springfr
amework.util,org.springframework.http,com.google.gson.reflect,org.eclip
se.emf.common.util,org.springframework.context,org.geppetto.frontend.me
ssaging,org.springframework.web.context.support";version="0.3.3",org.ge
ppetto.frontend.dashboard.service;uses:="org.geppetto.core.data,org.gep
petto.core.data.model,org.springframework.beans.factory.annotation,org.
springframework.core.io,org.geppetto.core.utilities,org.springframework
.web.bind.annotation,org.geppetto.core.manager,org.geppetto.core.common
,org.geppetto.core.beans,org.springframework.stereotype,org.geppetto.si
mulation.visitor,org.geppetto.model.util,org.geppetto.core.model,org.ec
lipse.emf.ecore.util,org.eclipse.emf.ecore,org.geppetto.model,org.apach
e.commons.logging,org.apache.shiro,org.apache.shiro.subject";version="0
.3.3",org.geppetto.frontend.messages;uses:="org.geppetto.frontend,com.g
oogle.gson";version="0.3.3",org.geppetto.frontend.messaging;uses:="org.
apache.commons.logging,org.geppetto.frontend.messages,org.apache.catali
na.websocket,com.google.gson";version="0.3.3",org.geppetto.frontend.tes
ts;uses:="com.google.gson.annotations";version="0.3.3"
Import-Bundle: org.springframework.aop;version="4.2.4.RELEASE",org.sprin
gframework.webmvc;version="4.2.4.RELEASE",org.apache.commons.logging
Import-Package: com.fasterxml.jackson.core;version="[2.8,3)",com.fasterx
ml.jackson.core.type;version="[2.8,3)",com.fasterxml.jackson.databind;v
ersion="[2.8,3)",com.google.gson;version="[2.2,3)",com.google.gson.anno
tations;version="[2.2,3)",com.google.gson.reflect;version="[2.2,3)",jav
ax.servlet,javax.servlet.http,org.apache.catalina.websocket,org.apache.
commons.logging;version="[1.1,2)",org.apache.shiro;version="[1.2,2)",or
g.apache.shiro.authc;version="[1.2,2)",org.apache.shiro.realm;version="
[1.2,2)",org.apache.shiro.subject;version="[1.2,2)",org.apache.shiro.we
b.env;version="[1.2,2)",org.apache.shiro.web.servlet;version="[1.2,2)",
org.eclipse.emf.common.util,org.eclipse.emf.ecore,org.eclipse.emf.ecore
.util,org.eclipse.virgo.web.dm,org.geppetto.core.auth;version="[0.3,1)"
,org.geppetto.core.beans;version="[0.3,1)",org.geppetto.core.common;ver
sion="[0.3,1)",org.geppetto.core.data;version="[0.3,1)",org.geppetto.co
re.data.model;version="[0.3,1)",org.geppetto.core.datasources;version="
[0.3,1)",org.geppetto.core.manager;version="[0.3,1)",org.geppetto.core.
model;version="[0.3,1)",org.geppetto.core.s3;version="[0.3,1)",org.gepp
etto.core.services.registry;version="[0.3,1)",org.geppetto.core.simulat
ion;version="[0.3,1)",org.geppetto.core.utilities;version="[0.3,1)",org
.geppetto.model;version="[0.3,1)",org.geppetto.model.datasources;versio
n="[0.3,1)",org.geppetto.model.util;version="[0.3,1)",org.geppetto.simu
lation;version="[0.3,1)",org.geppetto.simulation.manager;version="[0.3,
1)",org.geppetto.simulation.visitor;version="[0.3,1)",org.osgi.framewor
k;version="[1.7,2)",org.springframework.beans.factory.annotation,org.sp
ringframework.cglib.beans,org.springframework.cglib.core,org.springfram
ework.cglib.proxy,org.springframework.cglib.reflect,org.springframework
.cglib.transform,org.springframework.cglib.util,org.springframework.con
text,org.springframework.context.event,org.springframework.core.io,org.
springframework.http,org.springframework.http.converter,org.springframe
work.stereotype,org.springframework.util,org.springframework.web.bind.a
nnotation,org.springframework.web.context,org.springframework.web.conte
xt.request,org.springframework.web.context.support
Tool: Bnd-1.50.0
Web-ContextPath: org.geppetto.frontend
Re: Multiple spring deployments on Virgo 3.7.M03? [message #1751497 is a reply to message #1751489] |
Tue, 10 January 2017 19:24 |
Member |
I just checked the packageImports in org.eclipse.virgo.kernel.userregion.properties and identified the export org.apache.commons.logging:
packageImports =\
org.eclipse.virgo.kernel.artifact.*;version="0",\
org.eclipse.virgo.nano.core;version="0",\
org.eclipse.virgo.nano.deployer.api.*;version="0",\
org.eclipse.virgo.nano.deployer.api;version="0",\
org.eclipse.virgo.nano.deployer;version="0",\
org.eclipse.virgo.kernel.deployer.core.event;version="0",\
org.eclipse.virgo.kernel.install.*;version="0",\
org.eclipse.virgo.kernel.osgi.*;version="0",\
org.eclipse.virgo.kernel.model;version="0",\
org.eclipse.virgo.kernel.model.management;version="0",\
org.eclipse.virgo.kernel.module;version="0",\
org.eclipse.virgo.kernel.equinox.extensions.hooks;version="0",\
org.eclipse.virgo.nano.serviceability;version="0",\
org.eclipse.virgo.nano.serviceability.*;version="0",\
org.eclipse.virgo.kernel.services.work;version="0",\
org.eclipse.virgo.nano.shim.*;version="0",\
org.eclipse.virgo.medic.*;version="0",\
org.eclipse.virgo.repository;version="0",\
org.eclipse.virgo.repository.*;version="0",\
org.eclipse.virgo.util.*;version="0",\
org.apache.commons.logging;version="[1.0.0,2.0.0)",\
org.apache.commons.logging.impl;version="[1.0.0,2.0.0)",\
org.aspectj.*;version="[1.6.5.RELEASE,2.0.0)",\
org.osgi.service.event;version="0",\
org.osgi.service.log;version="0",\
org.osgi.service.http;version="0",\
javax.servlet;version="2.6.0",\
javax.servlet.*;version="2.6.0",\
org.eclipse.equinox.region;version="1",\
ch.qos.logback.*;version="[1.0.0,2.0.0)",\
org.slf4j;version="[1.6.4,2)",\
org.slf4j.helpers;version="[1.6.4,2)",\
org.slf4j.spi;version="[1.6.4,2)",\
org.springframework.util;version="[4.2.1,5)"
Also when I start Virgo Tomcat Server 3.7.0.M03, go to the Web Admin Console I can see that org.apache.commons.logging: 1.2.0.v20151023-1447 bundle is active and used by org.eclipse.gemini.blueprint.core: 2.0.0.RELEASE bundle:
Can you please check on your side if you can see the same?
Dani
Current Time: Sat May 11 19:36:56 GMT 2024
Powered by FUDForum. Page generated in 0.03150 seconds
