problem string concat operation OclUndefined ? [message #1746978] |
Tue, 08 November 2016 10:26 |
salha salha Messages: 97 Registered: February 2016 |
Member |
Hi, when i generate getRule1() :
lazy rule Rule2Rule{
from f:GrammAcme!Rule
to t:MMAcme!Rule(
ruletext<-thisModule.getRule1()
helper def: getRule1(f:GrammAcme!Rule):String=
if not f.designRuleExpression.qt.formalParam.oclIsUndefined() then
if not f.designRuleExpression.qt.designRuleExpression.qb.oclIsUndefined() then
if not f.designRuleExpression.qt.designRuleExpression.qb.orExpression.impliesExpression.iffExpression.equalityExpression.relationalExpression.additiveExpression
.multiplicativeExpression.unaryExpression.primitiveExpression.ruleExpression.oclIsUndefined() then
.multiplicativeExpression.unaryExpression.primitiveExpression.ruleExpression.qb.orExpression.impliesExpression.iffExpression.equalityExpression.relationalExpression
.additiveExpression.multiplicativeExpression.unaryExpression.primitiveExpression.id.oclIsUndefined() then
f.nameRule +' '+ '='+' ' + f.typeRule +' '+ f.designRuleExpression.qt.typeExp + ' '+ f.designRuleExpression.qt.nameComponent
+ ' '+':'+' ' +f.designRuleExpression.qt.formalParam.type
+ ' '+'in'+ ' '+ f.designRuleExpression.qt.setExpression.nameSetReference
+'.' + f.designRuleExpression.qt.setExpression.set.toString().regexReplaceAll('Sequence',' ').replaceAll('{',' ').replaceAll('}',' ').replaceAll('\'',' ').trim()
.additiveExpression.multiplicativeExpression.unaryExpression.primitiveExpression.id.idName+'.'+f.designRuleExpression.qt.designRuleExpression.qb.orExpression.impliesExpression.iffExpression.equalityExpression.relationalExpression.additiveExpression
.additiveExpression.multiplicativeExpression.unaryExpression.primitiveExpression.id.iddNames.toString().regexReplaceAll('Sequence',' ').replaceAll('{',' ').replaceAll('}',' ').replaceAll('\'',' ').trim()
else OclUndefined endif
here i don't have a problem and i have this result :
<rules ruletext="rule10 = invariant forall ps : PortTWSService in self.PORTS | (ps.Prec) =="/>
when i generate getRule3() i don't have a problem
to t:MMAcme!Rule(
ruletext<-thisModule.getRule3()
helper def: getRule3(f:GrammAcme!Rule):String=
if not f.oclIsUndefined() then
if not f.designRuleExpression.qt.designRuleExpression.oclIsUndefined() then
.multiplicativeExpression.unaryExpression.primitiveExpression.ruleExpression.qb.orExpression.impliesExpression.iffExpression.equalityExpression.relationalExpressions->first().
else OclUndefined endif ; ;
<rules ruletext="activer"/>
but when i concat getRule3() + getRule1() like this :
to t:MMAcme!Rule(
ruletext<-thisModule.getRule1()+thisModule.getRule3()
i have this problem :
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation not found: OclUndefined.+(org.eclipse.m2m.atl.engine.emfvm.lib.OclUndefined)
at Rule2Rule#296(Acme2Acme.atl[116:2-116:47])
local variables: self=Acme2Acme : ASMModule, f=IN!<unnamed>, t=OUT!<unnamed>
at Family2Family#113(Acme2Acme.atl[28:32-28:55])
local variables: self=Acme2Acme : ASMModule, f=IN!<unnamed>, q=IN!<unnamed>, j=OUT!WSM, e=IN!<unnamed>
at __applyFamily2AcmeFile#24(Acme2Acme.atl[12:17-12:46])
local variables: self=Acme2Acme : ASMModule, link=TransientLink {rule = Family2AcmeFile, sourceElements = {q = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@9a6d8c (eClass: org.eclipse.emf.ecore.impl.EClassImpl@1a36881 (name: FamilyBody) (instanceClassName: null) (abstract: false, interface: false)), f = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@11642c7 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@8201b4 (name: Family) (instanceClassName: null) (abstract: false, interface: false))}, targetElements = {j = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@d60adf (eClass: org.eclipse.emf.ecore.impl.EClassImpl@14f5028 (name: AcmeFile) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}, f=IN!<unnamed>, q=IN!<unnamed>, j=OUT!WSM
at __exec__#8(Acme2Acme.atl)
local variables: self=Acme2Acme : ASMModule, e=TransientLink {rule = Family2AcmeFile, sourceElements = {q = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@9a6d8c (eClass: org.eclipse.emf.ecore.impl.EClassImpl@1a36881 (name: FamilyBody) (instanceClassName: null) (abstract: false, interface: false)), f = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@11642c7 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@8201b4 (name: Family) (instanceClassName: null) (abstract: false, interface: false))}, targetElements = {j = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@d60adf (eClass: org.eclipse.emf.ecore.impl.EClassImpl@14f5028 (name: AcmeFile) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}
at main#27(Acme2Acme.atl)
i don'tt unrestand what is the problem ??????
FUDForum. Page generated in 0.03098 seconds
