Home » Eclipse Projects » Eclipse Platform » Error on startup
Error on startup [message #330650] Thu, 07 August 2008 05:51 Go to next message
Originally posted by: steve.nospam.rainbird.mssint.nospam.com
My java classes are not compiling and I have no idea why.
the only thing I can see is in the log I have the following error.
!SESSION 2008-08-07
10:48:10.074 -----------------------------------------------
eclipse.buildId=M20070921-1145
java.version=1.6.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui.workbench 2 0 2008-08-07 10:48:19.874
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-08-07 10:48:19.874
!MESSAGE Conflict for
'AUTOGEN:::com.eviware.soapui.eclipse.request/com.eviware.so apui.eclipse.request.delete':
HandlerActivation(commandId=AUTOGEN:::com.eviware.soapui.ecl ipse.request/com.eviware.soapui.eclipse.request.delete,
handler=ActionDelegateHandlerProxy(null,com.eviware.soapui.e clipse.actions.EclipseDeleteRequestAction),
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@18c4a7f),sourcePriority=16384)
handler=ActionDelegateHandlerProxy(null,com.eviware.soapui.e clipse.actions.EclipseRenameRequestAction),
Any ideas?
TIA
Steve
Re: Error on startup [message #330652 is a reply to message #330650] Thu, 07 August 2008 06:55 Go to previous messageGo to next message
"Steve Rainbird" <steve.nospam.rainbird@mssint.nospam.com> wrote in message
news:g7egjf$7dv$1@build.eclipse.org...
> !SESSION 2008-08-07
> Any ideas?
> TIA
> Steve
BTW if it helps the only thing I can think of that happened yesterday that
might have caused this is that my pc (Vista) blue screened on me. :(
Steve
Re: Error on startup [message #330847 is a reply to message #330650] Thu, 14 August 2008 12:34 Go to previous message
If a -clean doesn't clear this up, the problem is that something (I'm
not sure what) registered
com.eviware.soapui.eclipse.actions.EclipseRenameRequestActio n and
com.eviware.soapui.eclipse.actions.EclipseDeleteRequestActio n for the
AUTOGEN:::com.eviware.soapui.eclipse.request/com.eviware.soa pui.eclipse.request.delete
command
They look like action sets, so unless you are using keybindings they
shouldn't present a problem.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Sorting table Viewer
Next Topic:code to test "objectClass" of object contribution of "popupMenus" extension-poin
Current Time: Thu Nov 06 20:05:34 EST 2025
Powered by FUDForum. Page generated in 0.03947 seconds
