Home » Eclipse Projects » Eclipse Platform » Control visibility of an action declared in plugin.xml
Control visibility of an action declared in plugin.xml [message #330601] Tue, 05 August 2008 06:29 Go to next message
Originally posted by: guillaume.x.bedard.jpmorganchase.com
Hi!
Does anyone know how to control the visibility of an action that is
declared in plugin.xml? I want to be able to filter out menu bar items.
Thanking you in advance,
Guillaume
Re: Control visibility of an action declared in plugin.xml [message #330627 is a reply to message #330601] Wed, 06 August 2008 04:24 Go to previous messageGo to next message
Hi Guillaume,
Which extension point do you use?
A brief howto which describes the visibility/enablement of actions
declared using the org.eclipse.ui.popupMenus extension point can be
found at
http://xpomul.bloggles.info/2008/07/24/using-advanced-featur es-in-eclipse-popup-menus/
Stefan
Re: Control visibility of an action declared in plugin.xml [message #330643 is a reply to message #330627] Wed, 06 August 2008 23:26 Go to previous message
The newer "menus" extension point has a visibleWhen clause. Check out the
extension point documentation, especially the examples at the end.
Craig
On Wed, 06 Aug 2008 10:24:32 +0200, Stefan Winkler wrote:
> Hi Guillaume,
>> items.
> found at
> Cheers,
> Stefan
Previous Topic:Setting prefrence 'Open Mode' programmatically
Next Topic:Checkbox in TableCells - Screenshots of Button fails
Current Time: Tue Nov 18 12:49:22 EST 2025
Powered by FUDForum. Page generated in 0.05191 seconds
