Re: Single binding for handling multiple things simultaneously [message #1743288 is a reply to message #1743200] |
Wed, 14 September 2016 05:37 |
Abin Mathew Abraham Messages: 11 Registered: August 2016 |
Junior Member |
Hi Kai,
Thanks for your response and valuable time. I thought 1 binding is meant for 1 thing. What I'm trying to do right now is to interface openHAB with Leshan server such that the end user should see the clients connected to the Leshan server and should be able to operate them from openHAB without having to operate the server directly. In this thread, https://www.eclipse.org/forums/index.php/t/1071679/ you have mentioned that the right mapping should be Thing=Device. So the binding which I'm trying to develop should be able to create things dynamically, and as devices are not same, I need to create different things dynamically in the same binding. This is the scenario. I hope you understood. (I'm new to openHAB/ESH, bindings etc.).
Can you tell me the flaws in my approach, the pros and cons? Can you explain how you will approach this problem? Please share some github link of binding source code where things and channels are created dynamically.
Thank you,
Abin
[Updated on: Wed, 14 September 2016 05:38] Report message to a moderator
FUDForum. Page generated in 0.03434 seconds
