Cannot find plan 'org.eclipse.virgo.kernel.userregion.blueprint' on startup [message #1742259] |
Thu, 01 September 2016 07:52 |
Stefan Zugal Messages: 7 Registered: October 2014 |
Hi guys,
we have a Virgo 3.6.4 running on Redhat 7.2 with Java 1.8. Everything works fine when starting Virgo the first time. After shutting down Virgo and trying to start up, the following logmessage appears:
[2016-08-31 21:53:50.679] system-artifacts <DE0700E> Cannot find plan 'org.eclipse.virgo.kernel.userregion.blueprint' version range '[0.0.0, oo)' in repository 'ext-ches-snaps-security-usr'.
[2016-08-31 21:53:50.752] system-artifacts <DE0700E> Cannot find plan 'org.eclipse.virgo.web.tomcat' version range '[0.0.0, oo)' in repository 'ext-ches-snaps-security-usr'.
[2016-08-31 21:53:50.759] system-artifacts <DE0700E> Cannot find plan 'org.eclipse.virgo.management' version range '[0.0.0, oo)' in repository 'ext-ches-snaps-security-usr'.
After deleting directory work, everything is back to normal again. We fixed the problem by adapting configuration/org.eclipse.virgo.repository.properties by setting the repository type of "ext" from "external" to "watched".
We have set the loglevel to debug and checked the logfiles, but could not find anything suspicious. Also, the exactly same Virgo is running nicely on Windows 10 and CentOS 7 (which should be quite similar to Redhat). Does anybody have an idea what the cause for this behaviour could be?
Stefan
[Updated on: Wed, 14 September 2016 14:09] Report message to a moderator
FUDForum. Page generated in 0.03358 seconds
