Home » Eclipse Projects » Eclipse Platform » Launching eclipse ganymede - "No application id has been found"
Launching eclipse ganymede - "No application id has been found" [message #330262] Wed, 23 July 2008 12:39 Go to next message
Originally posted by: lucas.satabin.gmail.com
Hello everybody,
I am facing a strange problem : I switched from Europa to Ganymede and
everything worked fine. But since the beginning of the week, I can not
launch eclipse anymore. In the log file I can see this :
!ENTRY org.eclipse.osgi 4 0 2008-07-23 18:34:56.514
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at java.lang.reflect.Method.invoke(libgcj.so.90)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
I didn't find any solution for this on internet, and I also reinstalled
a new package (classic) but the problem still persists.
Does anybody have any idea of the solution?
Thanks in advance
Lucas
Re: Launching eclipse ganymede - "No application id has been found" [message #330297 is a reply to message #330262] Thu, 24 July 2008 13:25 Go to previous message
if forgot to write it, before the first line I pasted, I have these ones:
!SESSION 2008-07-24 19:12:44.979
eclipse.buildId=I20080617-2000
java.version=1.6.0_07
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=fr_FR
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.equinox.app 0 0 2008-07-24 19:12:46.934
!MESSAGE Product org.eclipse.sdk.ide could not be found.
The solutions I found were: do not use the GNU jre, but I am not using
it. My .eclipseproduct and config.ini files are the original ones, and
the id value "org.eclipse.sdk.ide" is the default one. I really don't
find anything on Internet to solve this problem. I also installed an old
package (europa) and have the same problem. All these package worked
fine, that's why I really don't undertstand
Thanks in advance for any help
Lucas
Lucas Satabin a écrit :
> Hello everybody,
> !STACK 1
> at
> at
> at
> at
> at
> at
> Thanks in advance
> Lucas
Previous Topic:Eclipse 3.4 on hpux ia64: missing dependency libgcc_s.so.0
Next Topic:What eclipse Runnable/Job I should use to display progress on my view?
Current Time: Fri Nov 28 22:25:39 EST 2025
Powered by FUDForum. Page generated in 0.04801 seconds
