Plan with CXF DOSGi 3.1.6 fails to start [message #1739125] |
Wed, 27 July 2016 15:44 |
This is my first attempt at using a Virgo plan and I'm failiing miserably
First it complained about some of the version entries not being numeric:
name="org.apache.servicemix.bundles.jaxb-impl" version="2.2.11_1"
with a file called: org.apache.servicemix.bundles.jaxb-impl-2.2.11_1.jar
So I change the file names by replacing the _ with a . (which is also what is in the bundle manifest: Bundle-Version: 2.2.11.1).
All good, the result is the attached plan, now I'm getting the following error on the very first bundle:
[2016-07-27 16:39:08.738] ERROR fs-watcher org.eclipse.virgo.medic.eventlog.default DE0003E Install failed for plan 'cxf-dosgi-plan' version '1.8.0'.
[2016-07-27 16:39:08.738] INFO fs-watcher System.out org.eclipse.virgo.nano.deployer.api.core.DeploymentException: Deployment of plan 'cxf-dosgi-plan' version '1.8.0' in scope 'null' failed: bundle 'geronimo-osgi-registry' in version range '[1.1.0, oo)' not found
I copied all the JARs from the DOSGi 1.8.0 release to ext/usr and the file "geronimo-osgi-registry-1.1.jar" exists.
The contents of the bundle also states Bundle-Version: 1.1
Is the naming incorrect? Have I misunderstood plans?
Re: Plan with CXF DOSGi 3.1.6 fails to start [message #1739129 is a reply to message #1739125] |
Wed, 27 July 2016 15:49 |
GianMaria Romanato Messages: 57 Registered: November 2015 |
Member |
Hi Bill,
Maybe "geronimo-osgi-registry" is the bundle name, not the symbolic name?
The bundle name attribute in the plan is not expected to contain the Jar file name, but rather the symbolic name of the bundle.
With respect to the version, you can safely omit it as it is not mandatory, as long as you don't have multiple versions of the same bundle in the repository folder(s).
GianMaria.
Edited: rephrased a sentence to make it easier to understand.
[Updated on: Wed, 27 July 2016 15:51] Report message to a moderator
Re: Plan with CXF DOSGi 3.1.6 fails to start [message #1739198 is a reply to message #1739125] |
Thu, 28 July 2016 09:40 |
The plan starts and all the defined bundles are resolved and running.
I haven't included CXF's jetty bundle as I don't want that starting up. I have configured SPNEGO single sign on in Virgo's tomcat and I don't want to have to manage 2 web servers.
I registered a service whose interface is annotated with the javax.jws annotations.
And in the props I have also added the following values:
service.exported.interfaces = my.interface.Name
service.exported.configs = org.apache.cxf.ws
context.registerService( my.interface.Name.class, myImpl, props );
Everything works but I must still be missing something.
It doesn't look like CXF registers itself with tomcat as a servlet and I don't see anything in the logs that would point to anything in that direction.
Can some kind soul point me in the right direction please?
FUDForum. Page generated in 0.03232 seconds
