WindowBuilder DesignerException 1100 [message #1738907] |
Mon, 25 July 2016 22:42 |
Alan Doran Messages: 1 Registered: July 2016 |
Junior Member |
I get the following error when I try to open the design tab for a file I created with WindowBuilder which runs/debugs correctly.
WindowBuilder error
No detailed description found for error (1100).
Hide stack trace.
Stack trace:
org.eclipse.wb.internal.core.utils.exception.DesignerException: 1100 (No description).
at org.eclipse.wb.internal.layout.group.model.GroupLayoutCodeSupport.parse(GroupLayoutCodeSupport.java:100)
at org.eclipse.wb.internal.layout.group.model.GroupLayoutSupport.parse(GroupLayoutSupport.java:184)
at org.eclipse.wb.internal.layout.group.model.GroupLayoutSupport$2.bindComponents(GroupLayoutSupport.java:91)
at sun.reflect.GeneratedMethodAccessor161.invoke(Unknown Source)
at org.eclipse.wb.core.model.broadcast.BroadcastSupport$1.intercept(BroadcastSupport.java:208)
at org.eclipse.wb.core.model.broadcast.JavaEventListener$$EnhancerByCGLIB$$e418be7f.bindComponents(<generated>)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.getRoot(JavaInfoParser.java:404)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parseRootMethods(JavaInfoParser.java:322)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:268)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.access$9(JavaInfoParser.java:238)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:153)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:1)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:159)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:151)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:534)
at org.eclipse.wb.internal.core.editor.DesignPage.access$9(DesignPage.java:522)
at org.eclipse.wb.internal.core.editor.DesignPage$8$1.run(DesignPage.java:449)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:186)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4761)
at org.eclipse.wb.internal.core.editor.DesignPage$8.run(DesignPage.java:446)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:463)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:371)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:500)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF_withProgress(DesignPage.java:465)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:415)
at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:381)
at org.eclipse.wb.internal.core.editor.DesignPage.refreshGEF(DesignPage.java:392)
at org.eclipse.wb.internal.core.editor.actions.RefreshAction.run(RefreshAction.java:46)
at org.eclipse.wb.internal.core.editor.actions.DesignPageAction.run(DesignPageAction.java:34)
at org.eclipse.wb.internal.core.editor.errors.JavaExceptionComposite.doRefresh(JavaExceptionComposite.java:87)
at org.eclipse.wb.internal.core.editor.errors.ExceptionComposite$3.widgetSelected(ExceptionComposite.java:129)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Caused by: java.lang.NullPointerException
at org.eclipse.wb.internal.layout.group.model.GroupLayoutParserVisitor2.setSize(GroupLayoutParserVisitor2.java:294)
at org.eclipse.wb.internal.layout.group.model.GroupLayoutParserVisitor2.endVisit(GroupLayoutParserVisitor2.java:123)
at org.eclipse.jdt.core.dom.MethodInvocation.accept0(MethodInvocation.java:241)
at org.eclipse.jdt.core.dom.ASTNode.accept(ASTNode.java:2711)
at org.eclipse.jdt.core.dom.ASTNode.acceptChild(ASTNode.java:2759)
at org.eclipse.jdt.core.dom.MethodInvocation.accept0(MethodInvocation.java:234)
at org.eclipse.jdt.core.dom.ASTNode.acceptChildren(ASTNode.java:2782)
at org.eclipse.jdt.core.dom.MethodInvocation.accept0(MethodInvocation.java:239)
at org.eclipse.wb.internal.layout.group.model.GroupLayoutCodeSupport.parseGroup(GroupLayoutCodeSupport.java:119)
at org.eclipse.wb.internal.layout.group.model.GroupLayoutCodeSupport.parse(GroupLayoutCodeSupport.java:97)
... 61 more
Full context stack trace:
... 61 more
FUDForum. Page generated in 0.02816 seconds
