Home » Archived » Eclipse SmartHome » Launch configuration for Smarthome Designer for Windows missing
Launch configuration for Smarthome Designer for Windows missing [message #1736095] |
Sat, 25 June 2016 16:57 |
Martin Herbst Messages: 4 Registered: August 2014 |
Junior Member |
I have installed an Smarthome development environment (with the help of Eclipse Installer) on Windows 10 with JDK 8 64 Bit. Build after installation was fine.
But when I try to execute the Smarthome Designer I have some problems. The targetplatform project contains only a launch configuration for Mac. I modified it by adding the correct SWT plugin for Windows 64 Bit, but I am not able to start the designer.
The console shows the following error messages. The last message about the invalid thread access is probably caused by the other errors. Need some help to get a working launch configuration.
!SESSION 2016-06-25 18:46:52.352 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_92
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.smarthome.designer.core.product
Command-line arguments: -product org.eclipse.smarthome.designer.core.product -data E:\Develop\smarthome-master\ws/../smarthome-designer -dev file:E:/Develop/smarthome-master/ws/.metadata/.plugins/org.eclipse.pde.core/SmartHome Designer (Mac)/dev.properties -os win32 -ws win32 -consoleLog
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.021
!MESSAGE Could not bind a reference of component ConfigDescriptionRegistry. The reference is: Reference[name = ConfigOptionProvider, interface = org.eclipse.smarthome.config.core.ConfigOptionProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addConfigOptionProvider, unbind = removeConfigOptionProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.022
!MESSAGE Could not bind a reference of component ConfigDescriptionRegistry. The reference is: Reference[name = ConfigDescriptionProvider, interface = org.eclipse.smarthome.config.core.ConfigDescriptionProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addConfigDescriptionProvider, unbind = removeConfigDescriptionProvider]
18:46:53.520 [Start Level: Equinox Container: 10fd476b-f43a-0016-1715-baae0aad52d3] DEBUG o.e.s.core.internal.PortableBase64 - PortableBase64 class is running on JavaSE >=8
18:46:53.522 [Start Level: Equinox Container: 10fd476b-f43a-0016-1715-baae0aad52d3] DEBUG o.e.s.core.internal.CoreActivator - Core bundle has been started.
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.527
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.binding.BindingInfoRegistry. The reference is: Reference[name = BindingInfoProvider, interface = org.eclipse.smarthome.core.binding.BindingInfoProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addBindingInfoProvider, unbind = removeBindingInfoProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.546
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.itemregistry. The reference is: Reference[name = ItemProvider, interface = org.eclipse.smarthome.core.items.ItemProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addProvider, unbind = removeProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.547
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.itemregistry. The reference is: Reference[name = ManagedItemProvider, interface = org.eclipse.smarthome.core.items.ManagedItemProvider, policy = dynamic, cardinality = 0..1, target = null, bind = setManagedProvider, unbind = removeManagedProvider]
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.itemregistry. The reference is: Reference[name = EventPublisher, interface = org.eclipse.smarthome.core.events.EventPublisher, policy = dynamic, cardinality = 0..1, target = null, bind = setEventPublisher, unbind = unsetEventPublisher]
18:46:53.556 [Component Resolve Thread] DEBUG o.e.s.c.i.i18n.LocaleProviderImpl - No language set, fallback to default system locale
18:46:53.918 [Component Resolve Thread] DEBUG o.e.s.core.common.ThreadPoolManager - Created thread pool 'ConfigStatusService' with size 5-10
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.918
!MESSAGE Could not bind a reference of component ConfigStatusService. The reference is: Reference[name = ConfigStatusProvider, interface = org.eclipse.smarthome.config.core.status.ConfigStatusProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addConfigStatusProvider, unbind = removeConfigStatusProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.929
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.type.ChannelTypeRegistry. The reference is: Reference[name = ChannelTypeProvider, interface = org.eclipse.smarthome.core.thing.type.ChannelTypeProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addChannelTypeProvider, unbind = removeChannelTypeProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.939
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.firmware.FirmwareRegistry. The reference is: Reference[name = FirmwareProvider, interface = org.eclipse.smarthome.core.thing.firmware.FirmwareProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addFirmwareProvider, unbind = removeFirmwareProvider]
18:46:53.942 [Component Resolve Thread] DEBUG o.e.s.core.common.ThreadPoolManager - Created scheduled thread pool 'FirmwareUpdateService' of size 5
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.944
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.firmware.FirmwareUpdateService. The reference is: Reference[name = FirmwareUpdateHandler, interface = org.eclipse.smarthome.core.thing.binding.firmware.FirmwareUpdateHandler, policy = dynamic, cardinality = 0..n, target = null, bind = addFirmwareUpdateHandler, unbind = removeFirmwareUpdateHandler]
18:46:53.945 [ESH-FirmwareUpdateService-1] DEBUG o.e.s.c.t.f.FirmwareUpdateService - Running firmware status check.
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.948
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.internal.console.FirmwareUpdateConsoleCommandExtension. The reference is: Reference[name = FirmwareUpdateHandler, interface = org.eclipse.smarthome.core.thing.binding.firmware.FirmwareUpdateHandler, policy = dynamic, cardinality = 0..n, target = null, bind = addFirmwareUpdateHandler, unbind = removeFirmwareUpdateHandler]
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.959
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.ThingRegistry. The reference is: Reference[name = ThingProvider, interface = org.eclipse.smarthome.core.thing.ThingProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addProvider, unbind = removeProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.960
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.ThingRegistry. The reference is: Reference[name = ManagedThingProvider, interface = org.eclipse.smarthome.core.thing.ManagedThingProvider, policy = dynamic, cardinality = 0..1, target = null, bind = setManagedProvider, unbind = removeManagedProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.966
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.ThingRegistry. The reference is: Reference[name = ThingHandlerFactory, interface = org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, policy = dynamic, cardinality = 0..n, target = null, bind = addThingHandlerFactory, unbind = removeThingHandlerFactory]
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.970
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.link.ItemChannelLinkRegistry. The reference is: Reference[name = ItemChannelLinkProvider, interface = org.eclipse.smarthome.core.thing.link.ItemChannelLinkProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addProvider, unbind = removeProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.971
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.link.ItemChannelLinkRegistry. The reference is: Reference[name = ManagedItemChannelLinkProvider, interface = org.eclipse.smarthome.core.thing.link.ManagedItemChannelLinkProvider, policy = dynamic, cardinality = 0..1, target = null, bind = setManagedProvider, unbind = removeManagedProvider]
18:46:53.975 [Component Resolve Thread] DEBUG o.e.s.c.c.registry.AbstractRegistry - Provider 'org.eclipse.smarthome.core.thing.internal.ChannelItemProvider' has been added.
!ENTRY org.eclipse.equinox.ds 1 0 2016-06-25 18:46:53.977
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.type.ThingTypeRegistry. The reference is: Reference[name = ThingTypeProvider, interface = org.eclipse.smarthome.core.thing.binding.ThingTypeProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addThingTypeProvider, unbind = removeThingTypeProvider]
!ENTRY org.eclipse.osgi 4 0 2016-06-25 18:46:54.809
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:4441)
at org.eclipse.swt.SWT.error(SWT.java:4356)
at org.eclipse.swt.SWT.error(SWT.java:4327)
at org.eclipse.swt.widgets.Display.error(Display.java:1258)
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:764)
at org.eclipse.swt.widgets.Display.getHighContrast(Display.java:1864)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.setCSSContextVariables(E4Application.java:327)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:305)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:601)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.smarthome.designer.ui.internal.application.Application.start(Application.java:32)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
18:46:54.835 [Framework stop] DEBUG o.e.s.c.c.registry.AbstractRegistry - Provider 'ChannelItemProvider' has been removed.
18:46:54.853 [Framework stop] DEBUG o.e.s.core.internal.CoreActivator - Core bundle has been stopped.
An error has occurred. See the log file
E:\Develop\smarthome-master\smarthome-designer\.metadata\.log.
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option PermSize=128m; support was removed in 8.0
Current Time: Wed May 01 23:30:47 GMT 2024
Powered by FUDForum. Page generated in 0.03276 seconds
