[SOLVED] create_binding_skeleton errors [message #1734777] |
Sat, 11 June 2016 20:09 |
Juergen Messmer Messages: 4 Registered: June 2016 |
Junior Member |
I am trying to create a new binding, starting with the creation of a skeleton.
I cloned the repo https://github.com/eclipse/smarthome.git
When I run the script create_binding_skeleton.sh / or .cmd (tried both on linux/windows) in /extensions/binding I get the following error:
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 27.758 s
[INFO] Finished at: 2016-06-11T21:54:18+02:00
[INFO] Final Memory: 32M/78M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-archetype-plugin:2.4:generate (default-cli) on project pom: The desired archetype does not exist (org.eclipse.smarthome.archetype:org.eclipse.smarthome.archetype.binding.test:0.9.0-SNAPSHOT) -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] ...
Any help to solve the issue is appreciated.
Thx, Juergen
[Updated on: Tue, 14 June 2016 21:05] Report message to a moderator
FUDForum. Page generated in 0.04187 seconds
