Fail to publish maven project in Tomcat [message #1729548] |
Fri, 15 April 2016 10:50 |
seven lumi Messages: 1 Registered: April 2016 |
Junior Member |
Hi everyone.
Er... I'm feel worry for my maven project it cannot be publish in my tomcat 8, in servers
The issue thew when i set project properties -- > development assembly -- > add maven dependencies, and after set that, my tomcat cannot publish the project, but what if i remove maven depencies, it works good but without lib in file. The error like "Could not publish to the server.
java.lang.NullPointerException"
And the log in eclipse .metedata like:
!ENTRY org.eclipse.wst.server.core 4 0 2016-04-15 12:28:33.212
!MESSAGE Could not publish to the server.
!STACK 0
at org.eclipse.wst.common.componentcore.internal.util.VirtualReferenceUtilities.getDefaultProjectArchiveName(VirtualReferenceUtilities.java:81)
at org.eclipse.jst.j2ee.componentcore.J2EEModuleVirtualComponent.getJavaClasspathReferences(J2EEModuleVirtualComponent.java:338)
at org.eclipse.jst.j2ee.componentcore.J2EEModuleVirtualComponent.getNonManifestRefs(J2EEModuleVirtualComponent.java:242)
at org.eclipse.jst.j2ee.componentcore.J2EEModuleVirtualComponent.getReferences(J2EEModuleVirtualComponent.java:166)
at org.eclipse.jst.j2ee.componentcore.J2EEModuleVirtualComponent.getReferences(J2EEModuleVirtualComponent.java:214)
at org.eclipse.jst.j2ee.componentcore.J2EEModuleVirtualComponent.getReferences(J2EEModuleVirtualComponent.java:207)
at org.eclipse.jst.common.internal.modulecore.SingleRootUtil.hasConsumableReferences(SingleRootUtil.java:217)
at org.eclipse.jst.common.internal.modulecore.SingleRootUtil.validateSingleRoot(SingleRootUtil.java:165)
at org.eclipse.jst.common.internal.modulecore.SingleRootUtil.isSingleRoot(SingleRootUtil.java:93)
at org.eclipse.jst.common.internal.modulecore.SingleRootExportParticipant.canOptimize(SingleRootExportParticipant.java:88)
at org.eclipse.wst.common.componentcore.internal.flat.FlatVirtualComponent.canOptimize(FlatVirtualComponent.java:203)
at org.eclipse.wst.common.componentcore.internal.flat.FlatVirtualComponent.cacheResources(FlatVirtualComponent.java:185)
at org.eclipse.wst.common.componentcore.internal.flat.FlatVirtualComponent.fetchResources(FlatVirtualComponent.java:118)
at org.eclipse.wst.web.internal.deployables.FlatComponentDeployable.members(FlatComponentDeployable.java:227)
at org.eclipse.jst.j2ee.internal.deployables.J2EEFlexProjDeployable.members(J2EEFlexProjDeployable.java:267)
at org.eclipse.wst.server.core.internal.ModulePublishInfo.fillCache(ModulePublishInfo.java:314)
at org.eclipse.wst.server.core.internal.ModulePublishInfo.getDelta(ModulePublishInfo.java:396)
at org.eclipse.wst.server.core.internal.ServerPublishInfo.getDelta(ServerPublishInfo.java:366)
at org.eclipse.wst.server.core.internal.Server.getPublishedResourceDelta(Server.java:1575)
at org.eclipse.wst.server.core.model.ServerBehaviourDelegate.getPublishedResourceDelta(ServerBehaviourDelegate.java:698)
at org.eclipse.jst.server.tomcat.core.internal.TomcatServerBehaviour.getPublishedResourceDelta(TomcatServerBehaviour.java:958)
at org.eclipse.wst.server.core.model.ServerBehaviourDelegate.computeDelta(ServerBehaviourDelegate.java:874)
at org.eclipse.wst.server.core.model.ServerBehaviourDelegate.publish(ServerBehaviourDelegate.java:909)
at org.eclipse.wst.server.core.model.ServerBehaviourDelegate.publish(ServerBehaviourDelegate.java:774)
at org.eclipse.wst.server.core.internal.Server.publishImpl(Server.java:3157)
at org.eclipse.wst.server.core.internal.Server$PublishJob.run(Server.java:345)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
the log was too simple to find the points
and i'm try force update maven dependencies and recheckout the projects and change a new tomcat servers except reinstall eclipse, but not fine; so i thought is that a permission problem? but there was no log for that would someone have the same problem ?
any help appreciate.
FUDForum. Page generated in 0.03305 seconds
