Home » Eclipse Projects » Eclipse Platform » Cannot contribute custon ant task from fragment plugin
Cannot contribute custon ant task from fragment plugin [message #329119] Fri, 13 June 2008 05:07
I've tried to contribute Ant task using org.eclipse.ant.core.antTasks
extension point. When I use it in plugin.xml, everything works fine, but
when I use it in fragment.xml of another plugin (which is a fragment
actually) - Eclipse doesn't see this contributed task. How can I
contribute task to Ant from fragment plugin?
Previous Topic:How to programmatically find path to configuration directory?
Next Topic:3.4rc4, manual build failed
Current Time: Wed Nov 19 07:31:34 EST 2025
Powered by FUDForum. Page generated in 0.03634 seconds
