Copy Model Not Working - Attached Models For reference [message #1717190] |
Thu, 10 December 2015 15:51 |
Ts Patil Messages: 32 Registered: September 2015 |
Member |
I am having a model. Which having Three Processes
Model1
-ProcessA
-ProcessB
-ProcessC
ProcessA is starting the ProcessB and ProcessC as part of its functionality by using process:start command.
Model1 deployed and is working perfectly fine no issues everything is well.
Now I copied the Model1 and Created Model2 so my model2 is like this
Model2
-ProcessA
-ProcessB
-ProcessC
I opened the XPDL of copied model i.e. Model2 - changed the ID and Name to Model2 also changed the process Names which auto changed the ID's of process so now I have like this.
Model2
-WProcessA
-WProcessB
-WProcessC
I changed the process:start command for new process Name for model2
Now I deployed the both the models.
I executed processA of Model1 which internally call ProcessB completed it successfully.
Now I tried executing WProcessA of Model2 which internally calls WProcessB and it failed can not find a process with process name WProcessB
Now I redeployed only Model2 and executed WprocessA of Model2 which internally call WProcessB and completed it successfully.
but executing processA of Model1 which internally call ProcessB failed saying can not find a process with process name ProcessB
SO, My Problem is I copied from Model1 to Model2. But Looks like the model2 internally maintaining the connection with Model1 processes and when I deploy model1 it overwrite the model2 process. and when i deploy model2 it overwrite model1 processes.
Any Idea, solution, Thoughts on above problem statement
Attached Models For Reference
Thanks in advance.
[Updated on: Fri, 11 December 2015 05:38] Report message to a moderator
FUDForum. Page generated in 0.04347 seconds
