Hudson execute threads are getting dead [message #1715636] |
Tue, 24 November 2015 20:34 |
kumar madhina Messages: 1 Registered: November 2015 |
Junior Member |
When we try to submit a job our hudson server execute threads are getting dead.
This is the exception we are seeing in logs, Not sure what is causing the problem. We are using weblogic server . Any help will be appreciated.
Nov 24, 2015 2:22:25 PM hudson.triggers.SafeTimerTask run
SEVERE: Timer task hudson.model.Queue$MaintainTask@438eb988 failed
com.google.common.util.concurrent.UncheckedExecutionException: java.lang.NullPointerException
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2263)
at com.google.common.cache.LocalCache.get(LocalCache.java:4000)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:4004)
at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4874)
at hudson.model.RunMap$LazyRunValue.getBuild(RunMap.java:1559)
at hudson.model.RunMap$4.apply(RunMap.java:545)
at hudson.model.RunMap$4.apply(RunMap.java:541)
at com.google.common.collect.Lists$TransformingRandomAccessList.get(Lists.java:575)
at java.util.AbstractList$Itr.next(AbstractList.java:346)
at hudson.model.Job.getEstimatedDuration(Job.java:1317)
at hudson.model.queue.MappingWorksheet.<init>(MappingWorksheet.java:354)
at hudson.model.queue.MappingWorksheet.<init>(MappingWorksheet.java:336)
at hudson.model.Queue.maintain(Queue.java:990)
at hudson.model.Queue$MaintainTask.doRun(Queue.java:1741)
at hudson.triggers.SafeTimerTask.run(SafeTimerTask.java:43)
at java.util.TimerThread.mainLoop(Timer.java:512)
at java.util.TimerThread.run(Timer.java:462)
Caused by: java.lang.NullPointerException
at hudson.model.RunMap$LazyRunValueCache$1.load(RunMap.java:776)
at hudson.model.RunMap$LazyRunValueCache$1.load(RunMap.java:770)
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3599)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2379)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2342)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2257)
at hudson.model.RunMap$LazyRunValueCache.get(RunMap.java:793)
at hudson.model.RunMap$LazyRunValueCache.access$1900(RunMap.java:736)
at java.util.AbstractList$Itr.next(AbstractList.java:345)
at hudson.model.queue.MappingWorksheet.<init>(MappingWorksheet.java:353)
at hudson.model.queue.MappingWorksheet.<init>(MappingWorksheet.java:335)
FUDForum. Page generated in 0.03292 seconds
