Fresh Eclipse Install and Window Builder Design tab crash [message #1713176] |
Mon, 02 November 2015 02:08 |
Tom Moulton Messages: 2 Registered: November 2015 |
Junior Member |
I have a fresh install of Eclipse IDE for Java Developers that includes WindowBuilder and a few other packages.
I am trying to learn how to use WB and when I open a file with WindowBuilder Editor, the source tab looks fine, but if I click the DESIGN tab a progress window opens and then waits a short time and eclipse crashes.
I have tried simple files freshly created by eclipse as well as existing code.
The last time I got these messages, but they are not constant, so may just be noise
[xcb] Unknown request in queue while dequeuing
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
[xcb] Aborting, sorry about that.
java: ../../src/xcb_io.c:179: dequeue_pending_request: Assertion `!xcb_xlib_unknown_req_in_deq' failed.
The simple source file is
package myname;
import java.awt.BorderLayout;
import java.awt.EventQueue;
import javax.swing.JFrame;
import javax.swing.JPanel;
import javax.swing.border.EmptyBorder;
public class MainFrame extends JFrame {
private static final long serialVersionUID = 1L;
private JPanel contentPane;
* Launch the application.
EventQueue.invokeLater(new Runnable() {
public void run() {
try {
MainFrame frame = new MainFrame();
frame.setVisible(true);
} catch (Exception e) {
e.printStackTrace();
* Create the frame.
public MainFrame() {
setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
setBounds(100, 100, 450, 300);
contentPane = new JPanel();
contentPane.setBorder(new EmptyBorder(5, 5, 5, 5));
contentPane.setLayout(new BorderLayout(0, 0));
setContentPane(contentPane);
I also added a couple of screenshots as well
Any suggestions to get more specific details on why this is crashing?
This is really weird since this is a standard install!
Tom
FUDForum. Page generated in 0.03068 seconds
