Home » Archived » Eclipse Process Manager (Stardust) » Swift Functionality
Swift Functionality [message #1705471] Sun, 16 August 2015 11:41 Go to next message
kayvan jam is currently offline kayvan jamFriend
Member
Hi All.
there is an example usage of Swift message in stardust?
thanks in advance.
Re: Swift Functionality [message #1705873 is a reply to message #1705471] Wed, 19 August 2015 16:55 Go to previous message
Vikram Kodak is currently offline Vikram KodakFriend
Member
You can check following documentation links if that helps
http://help.eclipse.org/mars/index.jsp?topic=%2Forg.eclipse.stardust.docs.camel%2Fhtml%2Fcamel%2Fmessage-processing.htm&resultof=%22%53%57%49%46%54%22%20%22%73%77%69%66%74%22%20
http://help.eclipse.org/mars/index.jsp?topic=%2Forg.eclipse.stardust.docs.camel%2Fhtml%2Fcamel%2Fpush-use-case.htm&resultof=%22%53%57%49%46%54%22%20%22%73%77%69%66%74%22%20
Previous Topic:How to use user groups
Next Topic:Using a web application other than Stardust Portal
Current Time: Thu May 23 18:23:33 GMT 2024
Powered by FUDForum. Page generated in 0.03312 seconds
